cd player wont fit #663701 11/06/05 08:51 PM
BAZ Offline OP
I trimmed the plastic around the opening and now about 80% of the Eclipse deck fits. Its getting hung up on something. I have been driving around with the CD player like this for a while so its not that big of a deal. Just wondering if any of you guys have the same problem and what you did about it.
1994 Toyota X-Cab 4WD 22R-E 5 speed.
Re: cd player wont fit [Re: BAZ] #663702 11/06/05 09:09 PM
It is a major pain in the behind. I did alot of triming to the dash and bracket to make mine work. I did find out that places like Circuit City sell mounting kits that will allow it to slide right in. I wish I had taken that route.
Re: cd player wont fit [Re: BAZ] #663703 11/06/05 09:13 PM
BAZ Offline OP
How would the kit prevent it from getting hung up on stuff ? I cant make sense of it?
Re: cd player wont fit [Re: BAZ] #663704 11/06/05 09:26 PM
Rauch_Off_Road Offline
I know that when I installed the sterio in my 86 runner I used a kit and then I think that i had to flip the kit over for the sterio to fit. Toyota uses a shorter and slimmer deck then the common aftermarket stuff so you have to play with it a bit to get it to fit.
(aka suprathepeg, aka Sean)
Re: cd player wont fit [Re: Rauch_Off_Road] #663705 11/06/05 09:34 PM
stock87 Offline
Nope, Toyota uses the exact same size deck as everyone else, everyone just tries to use the DIN sleeve to install them. If you take the sleeve off and screw the deck directly to the factory mounting brackets, they will all fit like stock.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: cd player wont fit [Re: stock87] #663706 11/06/05 09:43 PM
Talon84X4 Offline
This is true, same thing happened with mine, i just had to install without the sleeve, and another edge peice that went around the faceplate. Couldn't ask for a better fit.
'84 PU low & slow
Central Valley Crawlers
Re: cd player wont fit [Re: stock87] #663707 11/06/05 09:48 PM
BAZ Offline OP
OK, i am so confused. My pocket is below the cd player. is It supposed to be the other way around? This sounds so dumb but if thats the case, how do I take the pocket out? It looks like i have to take the dash apart to get at the bolts. Sorry for my retardedness in advance and thanks for the replies. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: cd player wont fit [Re: BAZ] #663708 11/06/05 09:50 PM
BAZ Offline OP
Oh, and i definately had to trim the dash a little. No getting around that, the CD player was wider than the opening. Maybe its different from year to year. I'm talking about my '94 FYI.
Re: cd player wont fit [Re: stock87] #663709 11/06/05 11:04 PM
kuso Offline
Exactly. Should be the same size as every one else!
I have my sleeve on the bottom of the head unit and it fits perfectly! No trimmin' required! <img src="/forums/images/graemlins/smile.gif" alt="" />
-kuso <img src="/forums/images/graemlins/shiner.gif" alt="" />
'91 Toyota, X-cab, 3.0, SR5, 4x4, Automatic Leech Tranny, 31" Generics, "KaTooM Carrier" 201K and runnin' smooth!
Many a good man has failed because he had his wishbone where his backbone should have been.
--Unknown
Re: cd player wont fit [Re: kuso] #663710 11/07/05 12:03 AM
G
Greg_Canada Offline
If i don't use the sleeve, and put it in the original spot, it will fit perfectly, but the P/O already cut (hacked) up the bezel so i used the sleeve... Some day when i get around to it (and get a good price) i'll get a double-din touch screen that will fit in perfectly (we measured my cousins kenwood excelon and it will fit in perfectly...
89 4Runner
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6352 MB (Peak: 0.7585 MB) Data Comp: Off Server Time: 2026-06-12 18:34:20 UTC
