cd player wont fit
#663701
11/06/05 08:51 PM
I trimmed the plastic around the opening and now about 80% of the Eclipse deck fits. Its getting hung up on something. I have been driving around with the CD player like this for a while so its not that big of a deal. Just wondering if any of you guys have the same problem and what you did about it.
1994 Toyota X-Cab 4WD 22R-E 5 speed.
Re: cd player wont fit
[Re: BAZ]
#663702
11/06/05 09:09 PM
It is a major pain in the behind. I did alot of triming to the dash and bracket to make mine work. I did find out that places like Circuit City sell mounting kits that will allow it to slide right in. I wish I had taken that route.
[Re: BAZ]
#663703
11/06/05 09:13 PM
How would the kit prevent it from getting hung up on stuff ? I cant make sense of it?
[Re: BAZ]
#663704
11/06/05 09:26 PM
I know that when I installed the sterio in my 86 runner I used a kit and then I think that i had to flip the kit over for the sterio to fit. Toyota uses a shorter and slimmer deck then the common aftermarket stuff so you have to play with it a bit to get it to fit.
(aka suprathepeg, aka Sean) 89 v6 SWB truck "BLACK BEAUTY" EB valves, P&P head 30 over. 95 FZJ80. Lifted. locked and rollin on 33s (my dream machine)
[Re: Rauch_Off_Road]
#663705
11/06/05 09:34 PM
I know that when I installed the sterio in my 86 runner I used a kit and then I think that i had to flip the kit over for the sterio to fit. Toyota uses a shorter and slimmer deck then the common aftermarket stuff so you have to play with it a bit to get it to fit. Nope, Toyota uses the exact same size deck as everyone else, everyone just tries to use the DIN sleeve to install them. If you take the sleeve off and screw the deck directly to the factory mounting brackets, they will all fit like stock.
[Re: stock87]
#663706
11/06/05 09:43 PM
This is true, same thing happened with mine, i just had to install without the sleeve, and another edge peice that went around the faceplate. Couldn't ask for a better fit.
'84 PU low & slow Central Valley Crawlers
[Re: stock87]
#663707
11/06/05 09:48 PM
OK, i am so confused. My pocket is below the cd player. is It supposed to be the other way around? This sounds so dumb but if thats the case, how do I take the pocket out? It looks like i have to take the dash apart to get at the bolts. Sorry for my retardedness in advance and thanks for the replies. <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: BAZ]
#663708
11/06/05 09:50 PM
Oh, and i definately had to trim the dash a little. No getting around that, the CD player was wider than the opening. Maybe its different from year to year. I'm talking about my '94 FYI.
[Re: stock87]
#663709
11/06/05 11:04 PM
Exactly. Should be the same size as every one else! I have my sleeve on the bottom of the head unit and it fits perfectly! No trimmin' required! <img src="/forums/images/graemlins/smile.gif" alt="" /> -kuso <img src="/forums/images/graemlins/shiner.gif" alt="" />
'91 Toyota, X-cab, 3.0, SR5, 4x4, Automatic Leech Tranny, 31" Generics, "KaTooM Carrier" 201K and runnin' smooth!
Many a good man has failed because he had his wishbone where his backbone should have been. --Unknown
[Re: kuso]
#663710
11/07/05 12:03 AM
If i don't use the sleeve, and put it in the original spot, it will fit perfectly, but the P/O already cut (hacked) up the bezel so i used the sleeve... Some day when i get around to it (and get a good price) i'll get a double-din touch screen that will fit in perfectly (we measured my cousins kenwood excelon and it will fit in perfectly...
89 4Runner 3" BL, M/T locks, 33"bfg mt, bilstein, Kayline, tubebumper, toyotafiberglass panels TBI: Elocker,3.4 w/ORS,b+b,S2Sstg2cams,arias pistons,P+P intake,TRDs/c,URDpullies+7th,downey headers,MAPECU2,WEGO WB, SupraMAF,walboro255,stg4clutch, EPaOo2 sim
