Page 3 of 3 1 2 3
Re: Gas smell coming out of vents, STILL. [Re: Van91DSM] #664222 11/18/05 03:29 PM
OOP'S Offline
I'd recommend using some WD40 on the o-rings and not fuel. They will slide right in.
You can either replace the washers or just sand them down a little to make them flat again. They are cheap so I'd go with new ones.
The FSM says to use gas, so that is what I would use.
While sanding them flat does help, you need to make them "dead soft" for maximum sealing. To do this you need to anneal them. To do this, as stated above hang them on a piece of wire and heat them to cherry red, let cool. You can use a small propane torch to do this. Owing British MCÆs all my life I have annealed many a copper gasket including solid copper head gaskets.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Gas smell coming out of vents, STILL. [Re: Van91DSM] #664223 11/18/05 03:32 PM
I know I need to go ahead and replace all of my o-rings on the injectors and use some gas on them to help slide them back in to place. Do I need to replace the banjo washers on the fuel rail or will it be fine to use the existing ones? If I need to replace them, how many are there that I need to replace?
Anything else that I need to replace while I have it tore down that MIGHT be causing this gas leak?
You can either replace the washers or just sand them down a little to make them flat again. They are cheap so I'd go with new ones. I have also just reused crush washers in a pinch and not had problems too. Your pick.
I'd replace ALL of the little rubber hoses for vacuum and coolant that are easier to access while the intake is loose. I just did this on my 22re. <img src="/forums/images/graemlins/kewl.gif" alt="" />
I'd also recommend replacing the fuel pulse dampener, because I know they leak and they're very hard to see while the intake is on the engine. It's on the firewall end of the fuel rail, on the passenger side rail, below the intake mani.
So, where do I get a fuel pulse dampener and how much do they cost? Do I need to get all of my o-rings and banjo washers from the dealer or go to a parts store? Let me know...Thanks for the help.
Re: Gas smell coming out of vents, STILL. [Re: OOP'S] #664224 11/18/05 03:38 PM
Thanks, I have a feeling that the banjos might be my main problem since I just re-used them the first time instead of resealing them or replacing them....
Re: Gas smell coming out of vents, STILL. [Re: OOP'S] #664225 11/19/05 06:20 AM
V
Van91DSM Offline
I rarely am one to argue with the FSM as I'm a dealership tech, but I've used wd-40 on every single rubber o-ring and seal I've ever replaced and never (knock on wood) had any problems. <img src="/forums/images/graemlins/wink.gif" alt="" />
Very interesting about the copper washer treatment there. I did not know that. Kewl. <img src="/forums/images/graemlins/kewl.gif" alt="" />
'88 X-Cab 4x4
'00 4Runner
'91 Talon TSi
slacker Mitsu tech
Re: Gas smell coming out of vents, STILL. [Re: Van91DSM] #664226 11/21/05 04:42 PM
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6073 MB (Peak: 0.7065 MB) Data Comp: Off Server Time: 2026-06-17 00:30:04 UTC
