Webber carb any good? #664437 11/09/05 01:47 AM
sindersblue Offline OP
Got a chance to buy an 84 PU 22R w/Webber carb, and a header. It's kinda rusty but the price is right.
Any thoughts? <img src="/forums/images/graemlins/cheers.gif" alt="" />
"If you can't learn to do something well, learn to enjoy doing it poorly".
85 22RE, 5spd 4Runner project
87 Turbo Truck, Boost Controller, otherwise stock... for now.
86 Turbo 4Runner, Project
Re: Webber carb any good? [Re: sindersblue] #664438 11/09/05 04:34 AM
kyle-22r Offline
it's a good carb, simple to work on. most guys that don't like em don't know how to tune em <img src="/forums/images/graemlins/cheers.gif" alt="" />
'91 4x4 shortbed
22R-E, W56, the dd!
Re: Webber carb any good? [Re: kyle-22r] #664439 11/09/05 04:38 AM
SHAD Offline
I like my aisin carb <img src="/forums/images/graemlins/drunk.gif" alt="" />
86 Toyota 4 runner
35x12.5 BFG MT's, 4.56's XRC8 winch
My cardomain page
Re: Webber carb any good? [Re: SHAD] #664440 11/09/05 04:59 AM
kyle-22r Offline
the aisin is a good unit, but didn't work right on my stripped down engine. well, it did work well for the first couple months, then started having problems.
after a while i started building my engine, and found it was even less adequate on a modified engine. ran much too lean for me, only real option was a weber or aftermarket EFI...
'91 4x4 shortbed
22R-E, W56, the dd!
Re: Webber carb any good? [Re: kyle-22r] #664441 11/09/05 07:34 AM
L
lookmomnobrains Offline
i was just told recently that the aisin carb flows slightly more than the weber 32/36. why would it not work on a modded engine short of the 300 vacuum hoses on it?
87 4runner 33" bfg mt's no lift. dubbed the marine by my frinds. dead as of august 14 2005. 84 ex cab p/u 33"a/t, 3" suspension+3"bodylift, thorley header and 2.25xhaust, downey midrange cam+rocker set, very milled head! NO RUST!
Re: Webber carb any good? [Re: lookmomnobrains] #664442 11/09/05 04:37 PM
ArbitraryNotion Offline
remove the choke plates and yes, the asain flows more. but the asain has a vacumm actuated secondary that restricts alot of flow. I swear up and down that a 32/36 puts more to the seat of the pants meter than stock.
Its fun chirpin the 33's with locked 4.30 gears on the 86 2wd smile Yep, 32/36 and an EB crawler stick.
1986 Toyota 4x4 22wEBer
Ported EB Offroad H/O Head "Josh Cam"
Ported Intake & Weber38mm Carb
LCE Header & 2.25in Exhaust
RB 1" BL, RS5000, SAW Tbars
2011 FJ Cruiser - SOLD
Re: Webber carb any good? [Re: ArbitraryNotion] #664443 11/09/05 09:12 PM
kyle-22r Offline
i wouldn't call the aisin carb a "vacuum secondary", but that pointless secondary choke plate is vacuum activated. mine's got a lot more low end kick to it now with the weber.
not to mention the way i have it set up, there's very few moving parts.
'91 4x4 shortbed
22R-E, W56, the dd!
Re: Webber carb any good? [Re: kyle-22r] #664444 11/09/05 10:05 PM
L
so if the secondary choke plate is removed will it still choke and warm up properly?
Re: Webber carb any good? [Re: lookmomnobrains] #664445 11/10/05 05:20 PM
thats a good question... If I still ran a stock carb on any of my veh I might try it... smile
Re: Webber carb any good? [Re: ArbitraryNotion] #664446 11/10/05 06:46 PM
4WD22R Offline
A stock 22R carb flows 290 cfms and I hear talk about setting up a 22R carb for racing and flowing somewhere around 380cfms.....sounds pretty dang good to me. And you get to keep all of your stock emissions stuff (if that is important to you....) And you don't gotta worry about fixing it all the time.
<img src="/forums/images/graemlins/notooth.gif" alt="" /> just a thought.....
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6364 MB (Peak: 0.7591 MB) Data Comp: Off Server Time: 2026-06-13 21:06:20 UTC
