Webber carb any good?
#664437
11/09/05 01:47 AM
Got a chance to buy an 84 PU 22R w/Webber carb, and a header. It's kinda rusty but the price is right. Any thoughts? <img src="/forums/images/graemlins/cheers.gif" alt="" />
"If you can't learn to do something well, learn to enjoy doing it poorly".
85 22RE, 5spd 4Runner project 87 Turbo Truck, Boost Controller, otherwise stock... for now. 86 Turbo 4Runner, Project
Re: Webber carb any good?
[Re: sindersblue]
#664438
11/09/05 04:34 AM
it's a good carb, simple to work on. most guys that don't like em don't know how to tune em <img src="/forums/images/graemlins/cheers.gif" alt="" />
'79 sport 4x4 longbed <img src="/forums/images/graemlins/smile.gif" alt="" /> 20/22R hybrid with EB's OS valves, 268c cam, offy intake, weber 32/36, thorley header, 5 speed swap, 34" LTBs, downey 3" springs, marlin hysteer, 4.88s and locked
'91 4x4 shortbed 22R-E, W56, the dd!
[Re: kyle-22r]
#664439
11/09/05 04:38 AM
I like my aisin carb <img src="/forums/images/graemlins/drunk.gif" alt="" />
[Re: SHAD]
#664440
11/09/05 04:59 AM
the aisin is a good unit, but didn't work right on my stripped down engine. well, it did work well for the first couple months, then started having problems.
after a while i started building my engine, and found it was even less adequate on a modified engine. ran much too lean for me, only real option was a weber or aftermarket EFI...
[Re: kyle-22r]
#664441
11/09/05 07:34 AM
i was just told recently that the aisin carb flows slightly more than the weber 32/36. why would it not work on a modded engine short of the 300 vacuum hoses on it?
87 4runner 33" bfg mt's no lift. dubbed the marine by my frinds. dead as of august 14 2005. 84 ex cab p/u 33"a/t, 3" suspension+3"bodylift, thorley header and 2.25xhaust, downey midrange cam+rocker set, very milled head! NO RUST!
[Re: lookmomnobrains]
#664442
11/09/05 04:37 PM
remove the choke plates and yes, the asain flows more. but the asain has a vacumm actuated secondary that restricts alot of flow. I swear up and down that a 32/36 puts more to the seat of the pants meter than stock. Its fun chirpin the 33's with locked 4.30 gears on the 86 2wd  Yep, 32/36 and an EB crawler stick.
1986 Toyota 4x4 22wEBer Ported EB Offroad H/O Head "Josh Cam" Ported Intake & Weber38mm Carb LCE Header & 2.25in Exhaust RB 1" BL, RS5000, SAW Tbars
2011 FJ Cruiser - SOLD
[Re: ArbitraryNotion]
#664443
11/09/05 09:12 PM
i wouldn't call the aisin carb a "vacuum secondary", but that pointless secondary choke plate is vacuum activated. mine's got a lot more low end kick to it now with the weber.
not to mention the way i have it set up, there's very few moving parts.
[Re: kyle-22r]
#664444
11/09/05 10:05 PM
so if the secondary choke plate is removed will it still choke and warm up properly?
#664445
11/10/05 05:20 PM
thats a good question... If I still ran a stock carb on any of my veh I might try it...
#664446
11/10/05 06:46 PM
A stock 22R carb flows 290 cfms and I hear talk about setting up a 22R carb for racing and flowing somewhere around 380cfms.....sounds pretty dang good to me. And you get to keep all of your stock emissions stuff (if that is important to you....) And you don't gotta worry about fixing it all the time.
<img src="/forums/images/graemlins/notooth.gif" alt="" /> just a thought.....
-1986 TOYOTA 22R ZUK coil rear Torqued T-Bars Marlin HD clutch
AZTTORA #492 TLCA member
"I hear there's rumors on the Internets that we're going to have a draft." --George W. Bush
