Re: Webber carb any good?
[Re: 4WD22R]
#664447
11/10/05 07:50 PM
And where did you hear this? I do have one of those modded carbs laying around. There are little gains here and there by REMOVING emissions but nowhere near turning a stock asian into a Holly 350. Look at LCE's website, they have a racing carb they build and everything is removed. Its pretty funny to look at. I'm sure you have to manualy choke the carb either with your hand or a removeable plate, but once the engine is warm, the gains should be obvious.
Josh
1986 Toyota 4x4 22wEBer Ported EB Offroad H/O Head "Josh Cam" Ported Intake & Weber38mm Carb LCE Header & 2.25in Exhaust RB 1" BL, RS5000, SAW Tbars
2011 FJ Cruiser - SOLD
[Re: ArbitraryNotion]
#664448
11/11/05 07:12 AM
sorry, not sure about keepin the emissions stuff but that shouldn't affect how much the carb flows....and also I was a little off with my cfms, it's quoted to be able to flow around 360, not 380......... I read a article in the 4WD Toyota Owner magazine about carb tuning, seems you can do some pretty impressive things with that aisan carb. I've also heard from talkin to a guy at a toyota shop down here in Phoenix called ToyoWest, that in his opinion the aisan is the best unit you can use for the 22R as long as you set it up right. To be fair the carb would be nowhere near stock by the time your done....you can modify it to accept holley main jets,get a better primary booster, reshape the venturi and some other tricks. But then again your webber is about as far from stock as you can get and for those of us who need to pass a visual emissions test, somethin like this is a great alternative! Oh, BTW here's the site of the company that was interviewed in the article: Braswell Carburetion Check 'em out!
-1986 TOYOTA 22R ZUK coil rear Torqued T-Bars Marlin HD clutch
AZTTORA #492 TLCA member
"I hear there's rumors on the Internets that we're going to have a draft." --George W. Bush
[Re: 4WD22R]
#664449
11/11/05 07:27 AM
Not to hijack the thread, but does anyone know of a good place to find a Weber carb? (i.e. a 32/36).
I upgraded everything else when I did my rebuild (EB 261C cam,header,flowmaster exhaust, etc..), but I've neglected the carb. department. I wondering how much more a Weber would wake up my engine <img src="/forums/images/graemlins/smile.gif" alt="" />
-Darren
'84 Xtra Cab Sold <img src="/forums/images/graemlins/frown.gif" alt="" /> '96 Tacoma in progress <img src="/forums/images/graemlins/smile.gif" alt="" /> God forgives...rocks don't.
[Re: Jiingwon]
#664450
11/11/05 07:31 AM
ebay, or check the local classfieds or craigslist. they're no longer made, but there's so many of them out there, you should have no problem finding them.
'79 sport 4x4 longbed <img src="/forums/images/graemlins/smile.gif" alt="" /> 20/22R hybrid with EB's OS valves, 268c cam, offy intake, weber 32/36, thorley header, 5 speed swap, 34" LTBs, downey 3" springs, marlin hysteer, 4.88s and locked
'91 4x4 shortbed 22R-E, W56, the dd!
[Re: kyle-22r]
#664451
11/11/05 04:27 PM
They are still made. They are made here in the US now instead of Italy. http://www.racetep.com/weberX.html is a good site also. ToyoWest are a bunch of hacks and should die alot. I had them do a clutch for me and they cut my shifter boot out to get to the bolts. They then told me that it was like that! <img src="/forums/images/graemlins/barf.gif" alt="" /> This was all in my pre-mechanic stages of life but they also charged about 2-3x how much it should have cost. I had my engine rebuilt for how much the charged my dad for the clutch job. Bunch of hacks.
#664452
11/12/05 03:46 AM
actually, the carbs being made in the US to my knowlege are the RGM model, not a weber. pretty sure the 32/36 was only made in spain...
#664453
11/12/05 08:33 AM
mmmm good to know guess I won't go there again.....thanks ArbitraryNotion
[Re: 4WD22R]
#664454
11/12/05 09:25 AM
when did you get 33's arbitrary? any pics?
[Re: 87Toy4x4]
#664455
11/17/05 08:48 PM
They're on his dad's lifted 2WD...
89 4Runner 3" BL, M/T locks, 33"bfg mt, bilstein, Kayline, tubebumper, toyotafiberglass panels TBI: Elocker,3.4 w/ORS,b+b,S2Sstg2cams,arias pistons,P+P intake,TRDs/c,URDpullies+7th,downey headers,MAPECU2,WEGO WB, SupraMAF,walboro255,stg4clutch, EPaOo2 sim
[Re: lookmomnobrains]
#664456
11/24/05 11:20 PM
so if the secondary choke plate is removed will it still choke and warm up properly? I removed my secondary choke plate last weekend (stock Aisin carb).. I was searching to see if anybody has done this before and found this thread! For the most part it runs fine, however as soon as I step on the throttle it wants to die on me. I didn't have time to tinker around with it yet though:) I imagine it's just getting too much air when the secondary throttle plate begins to open (only happens when you're nearly at full throttle). Anyone have any ideas?
