Page 3 of 3 1 2 3
Re: My turbo motor is finally running...but with alot of pinging?? Any idea turbo goorus?? [Re: swamprunner] #664893 11/13/05 07:24 PM
swamprunner Offline OP
I got the new adjuster screws in and what a differnece. No more valve chatter. I took it for a ride and it did great. However, there is now a slight tap or knock present toward the rear of the motor. I'm not sure what it is, sounds like its up top somewhere. I used a long extention an it seems like its coming from the last two valves or the last cyl. Maybe one of the valves is adjusted wrong? But its more of a knock than a tap. Any ideas??
And the rear main seal might be leaking. I sure as hell hope not b/c I used a sleeve and new seal. But theres drips present on the bellhousing after a road test. Doesn't leak while just sitting there idling. I have a bad feeling about this.
85 SR5 4runner....Too many hours of work put into it, Hacked, Beaten, and Still running after all I've put it through
87 Turbo Pickup...Bought Her for $500 put another $500 in her and she's running like a dream.
Re: My turbo motor is finally running...but with alot of pinging?? Any idea turbo goorus?? [Re: swamprunner] #664894 11/13/05 07:40 PM
stock87 Offline
ON the bellhousing? Not coming out of it? Those half moon seals on the head are real easy to knock out of place, and you had the valve cover off to replace those screws. That'd be the first thing I'd check.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: My turbo motor is finally running...but with alot of pinging?? Any idea turbo goorus?? [Re: stock87] #664895 11/13/05 08:28 PM
It's not the half moon seals or the valve cover. I was hoping that was it but I let it idle for 15 min and watched the back of the valve cover an nothing leaked up there. Then I took it for a short ride and there was drips present at the bottom of the bell housing. I think its the rear main. Going to do a few more test runs before I decide to tear it down. I just don't understand why it would be leaking from there. I double checked everything b/c I didn't want this to happen.
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6010 MB (Peak: 0.6542 MB) Data Comp: Off Server Time: 2026-06-07 06:53:18 UTC
