Page 2 of 3 1 2 3
Re: Need to re-index steering wheel [Re: Jim_Paget] #664913 11/11/05 03:18 AM
onebadtrooper Offline
I also had a bent center link. Its not the link its self its bent where it connects the frame. I'll get a pic if you want.. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Need to re-index steering wheel [Re: onebadtrooper] #664914 11/11/05 03:20 AM
W
Wareagle Offline OP
Do you mind? Maybe, I'm looking for the wrong thing.
Re: Need to re-index steering wheel [Re: Wareagle] #664915 11/11/05 03:24 AM
not at all.. <img src="/forums/images/graemlins/cheers.gif" alt="" /> I'll go get one.....
Re: Need to re-index steering wheel [Re: Wareagle] #664916 11/11/05 03:24 AM
W
Wareagle Offline OP
PS: I might mention, that this trooper's steering wheel always seems to drift to towards the passenger side. Its never really pulled (wheel alignemnt) after a trail ride, but steeering wheel almost always moves a bit to the right.
PS2: I just took another look underneath. Steer parts and pieces between wheels and steering box look great. Not so sure between steering box and shaft. The splines that connect shaft to box, MIGHT be a little off. Still looks like wheel may have slipped. Keep in mind that I have a front lockright, so I fight <img src="/forums/images/graemlins/angry.gif" alt="" /> this puppy at times <img src="/forums/images/graemlins/smile.gif" alt="" />.
Re: Need to re-index steering wheel [Re: onebadtrooper] #664917 11/11/05 03:35 AM
Iluvmud Offline
Mark, is you are still going to pull the wheel keep a few things in mide. Holding down the brake pedal will not help to power down the air bag system any faster. The air bag control unit has a "batter" (for lack of a better word) that holds the charge incase of a massive wreck where batter power was lost the air bags could still deploy. The only way to make sure is just to wait the set period of time. Also, make sure that you disconect the air bag plug under the dash before you start to take apart the steering colum. It is a rather obivious yellow conector. After that remove the bolts holding the air bag on, and then unplug it from the clock switch. (as said by jessica, be carefully with air bag moduel as it can still deploy. we set one off with a 9 volt battery in class). Then you will need a puller...13.99 to buy or 22.00 to rent at advance. The wheel is splined onto the steering shaft. It will be helpfull to mark the cuttent location with a permant marker on the wheel and the shaft, that way you are sure of how many splines you are moving. Before doing all of that, double check your tie rods since they control toe. We did an alingment on mine and got everything within spec, but did not lock the sttering wheel so the wheel itself is a fe degrees off. I am gonna pull and relocate the wheel in the right palce). Sorry for the long post, but hope this helps. Gotta love Wyotech!!! <img src="/forums/images/graemlins/patriot.gif" alt="" />
8 inches of lift, 33s, custom bumpers and rockbars, powertrax, T-maxx 9000, lots o lights, and some bass in the trunk
Lifted, locked, and ready to rock!!! <img src="/forums/images/graemlins/evil.gif" alt="" />
[url=http://www.cardomain.com/memberpage/743285][/url]
Re: Need to re-index steering wheel [Re: Iluvmud] #664918 11/11/05 03:46 AM
Ok heres the pic. I put an arrow to show where to look. You have to look at the gap in yours to see if its bent. Look at the gap between this mount and the center link arm that connects to it.
Re: Need to re-index steering wheel [Re: onebadtrooper] #664919 11/11/05 03:53 AM
Starchild Offline
That's the Ideler arm. I've buggered up two of those.
That's most likely your problem.
An easy way to tell is to lie under the front while some one turns the wheel back and forth. You should be able to see movement in the shaft.
<img src="/forums/images/graemlins/cheers.gif" alt="" />Andre
"SERENITY NOW!"
Re: Need to re-index steering wheel [Re: Wareagle] #664920 11/13/05 05:36 PM
W
Wareagle Offline OP
Idler shaft might be slightly bent. I's have to pull to confirm. Speaking of which, does anyone have source for these things. Only place that I've found wants $170 w/o bar.
Re: Need to re-index steering wheel [Re: Wareagle] #664921 11/13/05 07:05 PM
You can get one at a junk yard for $20 probably. it might even come with the center link. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Need to re-index steering wheel [Re: Wareagle] #664922 11/13/05 11:02 PM
Starchild Offline
I've got a couple from salvage yards. They are stupid expensive new. I've got one laying around somewhere if you get in a pinch.
"SERENITY NOW!"
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6474 MB (Peak: 0.7527 MB) Data Comp: Off Server Time: 2026-06-22 18:12:47 UTC
