Re: Front shock install [Re: MontyMcV] #665236 11/11/05 10:11 PM
Kevin C Offline
How about two hose clamps with a connector link between them to hold the upper part of the KYB to the lower?
That should be easy easy to rig up in place. You can get some extra compression on the shock by prying agianst the top of it.
Yes, getting them back out is a pain!
Kevin
Re: Front shock install [Re: MarkG] #665237 11/12/05 01:40 AM
maniac28 Offline OP
MarkG, thank you very much, that's a excellent idea and I will do it in the morning. I'll let you know how it works out! thanks again.
Ian S.
Temecula, CA
1989 Montero LWB V6 LSD, BFG AT's, Daily Driver
Re: Front shock install [Re: MontyMcV] #665238 11/12/05 06:30 AM
LRJ4x4 Offline
Sure mine came with a nice compression strap right out of the box. I was thinking they were "normal shocks" and I cut the strap early. <img src="/forums/images/graemlins/frown.gif" alt="" /> Won't make that mistake again <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Front shock install [Re: LRJ4x4] #665239 11/12/05 04:25 PM
maniac28 Offline OP
My rear KYB's came with compression ties but my front's did not. Weird, especially since you need them on the front but not on the rear ones.
Ian S.
Temecula, CA
Re: Front shock install [Re: maniac28] #665240 11/12/05 10:23 PM
maniac28 Offline OP
Good news: it worked. I just test drove it, the shocks are nice. Of course the automotive gods are smiling, I noticed my radiator is leaking like a sieve, now I get to do that too. Hopefully one of the parts stores will have one, this is my only vehicle and I need to go back to school monday.
Ian S.
Temecula, CA
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6125 MB (Peak: 0.6763 MB) Data Comp: Off Server Time: 2026-06-23 11:03:37 UTC
