Re: Changing back to open diff [Re: Starchild] #665381 11/12/05 08:02 PM
mlclark Offline
Isuzu Moderator
Basically, for every 4.77 Trooper, there is a 10 bolt and a 12 bolt third. For every 4.77 Amigo, there is a 10 bolt and a D44(HD).
And just to emphasize the fact, there are not many 12-bolt 4.77's out there.
I thought there was a D44 4.77 set available. Something from a Geep application? Rubicon? XJ with the HD D44?
Michael
Re: Changing back to open diff [Re: mlclark] #665382 11/12/05 08:35 PM
Starchild Offline
The only D44 4.77's are Isuzu OEM for the 98' HD D44 axle. I beleive they are the "thick" style gears, but the non-standard pinion diameter used in the 2nd gen axle makes it difficult to use in the standard D44 in the 1st gen Rodeo. Theoretically, they can be made to work, but it hasen't been done to my knowledge. These 4.77's R&P are available through Isuzu, but they're around $400 or so.
From what I understand, the Rubicon uses thick 4.88's.
<img src="/forums/images/graemlins/cheers.gif" alt="" />Andre
"SERENITY NOW!"
Re: Changing back to open diff [Re: Starchild] #665383 11/12/05 09:06 PM
mlclark Offline
Isuzu Moderator
From the DC website, the are running 4.10's. Maybe the earlier ones were running the 4.88's?
Michael
Re: Changing back to open diff [Re: mlclark] #665384 11/13/05 02:57 AM
Rodeo Guy Offline
Actually, 98 and up, 4 cylinder automatic Rodeos also have 4.77s. But it has the weird pinion, and the housing comes with coil mounts, so they don't do you much good unless swapping into another second gen.
Mike
"Damn the carnage! Full throttle ahead!"
95.5 rodeo, 37" Trxus MT, dana 44/9", coil-overs, lockers..... http://www.cardomain.com/memberpage/550454
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6089 MB (Peak: 0.6650 MB) Data Comp: Off Server Time: 2026-10-24 02:34:16 UTC
