Changing back to open diff #665371 11/11/05 05:24 PM
Zubicon Offline OP
It's been so long ago since I put the lockright in my front end that I can't remember all of the parts that was involved in the third member. I still have the 4 spider gears. Is this all I need to take the bloody lockright out and bring it back to stock?
Also can I swap out the third member in the front that I presently have for a third member that has 4:77 gears? I thought this was discussed previouly but I sure cann't find it. What was the vehicles and years that had this ratio stock? I'm just thinking way ahead in case I win the lottery and are able to fix the tranny I'd like to get the front back to open diff and regear so that the tranny isn't screaming to keep up so that my newly licensed driver (my daughter) has something to go back and forth with to school and work with. It's starting to annoy me sitting in my driveway broke. I'm so close of just junking it and buying her something more suitable.
Re: Changing back to open diff [Re: Zubicon] #665372 11/11/05 06:52 PM
RobG Offline
you will need the 4 thrust washers that sat behind each gear.
yes, all 10-bolt front 3rd members are interchangable.
'89 Trooper RS (2dr SWB). Some other Troopers had them as well, but these are hard to identify. Some say look for snowflake rims and the wide tire package. Others say a certain option code (S2J I believe). But you'll have to confirm with these. However, consensous is all 1st gen RS's came with them.
-Rob
Re: Changing back to open diff [Re: RobG] #665373 11/11/05 07:14 PM
Starchild Offline
I got my 4.77 3rd on Car-part.com. It's a stock ratio in a 98 Amigo (4cyl I think).
Not sure what your vehicle is, but re-gearing the rear may not be as straight foward <img src="/forums/images/graemlins/scared.gif" alt="" />
<img src="/forums/images/graemlins/cheers.gif" alt="" />Andre
"SERENITY NOW!"
Re: Changing back to open diff [Re: RobG] #665374 11/11/05 07:57 PM
mlclark Offline
Isuzu Moderator
Two. There are only thrust washers for the side gears, not the spiders.
Michael
Re: Changing back to open diff [Re: Starchild] #665375 11/11/05 09:01 PM
strawmyers Offline
Isuzu Moderator
Yes, early model year '98 4cyl 4WD Amigos had them. And the option code is actually S2J. THREAD
Sean Strawmyer
Re: Changing back to open diff [Re: strawmyers] #665376 11/12/05 05:59 PM
Paddler Offline
Maybe I'm getting this all confused. Is it the front or the rear third member that the 4.77's are hard to come by?
1995 Honda Passport;
Some people wait a life time for their ship to sail in, while others simple grab the oars and begin paddling
Yours truely
http://www.zutah.com
Re: Changing back to open diff [Re: Paddler] #665377 11/12/05 06:13 PM
Starchild Offline
I beleive the rear are more rare, since the front 4.77's were offered in more applications.
"SERENITY NOW!"
Re: Changing back to open diff [Re: Paddler] #665378 11/12/05 06:15 PM
Smiley Offline
With so many 32 & 33-inch tire-wearing Isuzu owners all vying for them, BOTH the front & rear 4.77s are getting pretty hard to findà
However, if more folks start doing what Andre (Starchild) did û and install an Isuzu 4.77 in the front, while re-gearing their rear D-44 (in a Rodeo/Passport) with an æoff-the-shelfÆ 4.88 R&P û it probably wonÆt be long before the front 4.77s are considerably harder to find than the rears.
<img src="/forums/images/graemlins/smile.gif" alt="" />
Six Isuzus, so far... still have three of them.
Re: Changing back to open diff [Re: Starchild] #665379 11/12/05 06:22 PM
Smiley Offline
HUH? <img src="/forums/images/graemlins/confused.gif" alt="" />
OK, now I'm confused!
Wait - Are you referring to the fact that the 4.77 10-bolt front 3rd member was available (when equipped as such) in ALL of the Isuzu platforms, versus the rears being either an Isuzu 12-bolt or a Dana 44, depending?
Hmmmmmmm...
I guess maybe there are a few more front third members out there than rears.
Nevermind <img src="/forums/images/graemlins/ignore.gif" alt="" />
Re: Changing back to open diff [Re: Smiley] #665380 11/12/05 07:15 PM
Starchild Offline
Basically, for every 4.77 Trooper, there is a 10 bolt and a 12 bolt third. For every 4.77 Amigo, there is a 10 bolt and a D44(HD).
Therefore more 10 bolts out there <img src="/forums/images/graemlins/smile.gif" alt="" />
"SERENITY NOW!"
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6437 MB (Peak: 0.7670 MB) Data Comp: Off Server Time: 2026-10-22 15:47:03 UTC
