Re: control arm bolt [Re: Adam F] #665453 11/13/05 06:39 PM
Scerb Offline OP
.. thats what I was using before I got the sledge..
Thanks for the ideas guys. I'm on lunch break right now, gonna go out this evening after work and get that fecker out. I got buncha new sawzall blades, new tip for torch and anger <img src="/forums/images/graemlins/angry.gif" alt="" /> it'll come out by dark <img src="/forums/images/graemlins/evil.gif" alt="" /> I think that bottle jack idea sounds good though - gonna try that first <img src="/forums/images/graemlins/kewl.gif" alt="" />
-Scerb
Re: control arm bolt [Re: Scerb] #665454 11/13/05 08:35 PM
brentox Offline
there are very few obstacles that cannot be overcome with a sawzall, heat, hammers, bottle jacks, and anger.... <img src="/forums/images/graemlins/shiner.gif" alt="" />
92 Extended Cab 4x4, 3.0 5-Speed Scratched, Dented and Rusted.
Re: control arm bolt [Re: brentox] #665455 11/14/05 01:06 AM
Scerb Offline OP
yay! I got it out <img src="/forums/images/graemlins/smile.gif" alt="" />
I tried jack, torch and sawzall - none were working at all. So i got smart:
I put breaker bar on bolt, and turned the control arm until I saw the bushing skip around the bolt. i was then able to punch it out about an inch, until the threads got hung up on bushing again.
I then used sawzall to cut the head/oval thingy off the bolt, and was then able to punch it out the oppostie direction.
Thanks for the help guys!
-Scerb
Re: control arm bolt [Re: Scerb] #665456 11/14/05 01:43 AM
TinyTruck Offline
good, I thought I was gonna have to hitchhike my way over there to show you how a real man does things
1988 YOAT "Stumpy"
-Lock-Right -Fabtech spare tire carrier
-3in PA BL -Custom Flatbed
-32x11.5 cooper mall-terrains <BALD>
Re: control arm bolt [Re: TinyTruck] #665457 11/14/05 05:35 AM
87Toy4x4 Offline
i would get new poly bushings instead of another set of stock rubber ones.
Re: control arm bolt [Re: 87Toy4x4] #665458 11/14/05 02:15 PM
maxxis85 Offline
i had the same problem removing a kit i purchased used. I am attempting to install it on my truck and i know i will have this problem. Ill try different things if the bolts are stuck. If i have to cut them, where to get new cam bolts.
1989 TOYOTA PICKUP 4"trailmaster, 3" Body Lift 8,000 lb warn winch, q-78 tsl super swampers
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6156 MB (Peak: 0.6851 MB) Data Comp: Off Server Time: 2026-06-17 11:24:23 UTC
