Re: Rough Idle/misfire problem please help
[Re: willzrunna96]
#665752
11/18/05 07:08 AM
Spark plugs, dist. cap and rotor.
'88 X-Cab 4x4 '00 4Runner '91 Talon TSi slacker Mitsu tech
[Re: Van91DSM]
#665753
11/18/05 07:15 AM
Spark plugs, dist. cap and rotor. Ah! Don't forget the coil my fellow Glendaleian(however you spell that) <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
-1986 TOYOTA 22R ZUK coil rear Torqued T-Bars Marlin HD clutch
AZTTORA #492 TLCA member
"I hear there's rumors on the Internets that we're going to have a draft." --George W. Bush
[Re: 4WD22R]
#665754
11/19/05 03:36 AM
the plugs are new and the cap and rotor are about 10,000 miles ago but show no wear. coil...yea thats 185,000 miles old. good possibility. ive noticed it only misses when the the engine warms up. but now thats its cold outside the thing runs like a raped ape. ill check out the coil with an ohm meter tommorow thanks for the idea
91 pickup 5.29's US GEAR.35x 12.50 trxus m/t.5 speed swap- SOLD! 96 4Runna limited-toytec/OME lift,diff drop Nitto 285/75/16 Elocked=butter 07 FJ cruiser 3" DR coilovers 285/75/16 nitto TG. allpro sliders
[Re: willzrunna96]
#665755
11/19/05 04:25 AM
My 2WD 22re was acting up big time.It was running rough and really crappy on the acceleration.I took a wild guess by changing the stock spark plug wires for some Magnecore wires that I bought over Ebay.Instant fix the truck is running great from idle to mid and high throttle.Maybe its your time to change your wires.
88 4x4 22re 86 2wd 1-ton 22re 91 2wd 22re
[Re: Vonka]
#665756
11/19/05 05:03 AM
just replaced the wires 2 days ago...no luck
[Re: willzrunna96]
#665757
11/19/05 06:23 AM
Have any of you dug into your fuel injector splices yet? After all, you DID just have that engine out, so you're messing with the harnessing....
[Re: willzrunna96]
#665758
11/19/05 06:24 AM
ive noticed it only misses when the the engine warms up. Check all of the ohms on the injectors too. Maybe run some good quality fuel injector cleaner thru the tank as well.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6236 MB (Peak: 0.6977 MB) Data Comp: Off Server Time: 2026-06-07 09:05:57 UTCValid HTML 5 and Valid CSS
