Page 2 of 3 1 2 3
Re: Low Fuel Light not Coming On [Re: TheToeCutter] #666326 11/16/05 04:02 AM
jasonmt Offline
Your right, there is a bulb and I tested it to a 9 volt battery. Bulb is fine so its either that the light is workikng (I just haven't let fuel go down to sensor level) or the sensor is broken.
I looked in haynes manual and owners manual couldn't find, At how many gallons left should the LOW FUEL LIGHT COME ON ? Or about how many miles left in tank ? I believe tank capacity is 17.2 gallons
Thanks for help guys.
Like Brian said there are two models of fuel level senders, one has 4 wires and the low fuel light sensor and one has 2 wires and no low fuel light sensor.
To test remove sender assembly from tank. Check for continuity across terminals 1 and 4 on plug. When the sensor is dry it should have continuity and when it is submerged in fuel it should have no continuity.
4 wire with low fuel light sensor (Low fuel sensor running N-E):
2 wire with NO low fuel light sensor:
Re: Low Fuel Light not Coming On [Re: jasonmt] #666327 11/16/05 04:13 AM
87Toy4x4 Offline
mine didnt even look like the 4 wire one from the factory. i also swapped my gauges out for sr5 ones so i dont even know if it would work regardless. i know the stock gauges had a fuel light but idk about my current ones.
Re: Low Fuel Light not Coming On [Re: 87Toy4x4] #666328 11/16/05 05:42 AM
4WD22R Offline
AFAIK my '86 dontn't even have a low fuel light....or I'm having the same problem. I even ran the tank dry once when I first got it....no 'Fuel Level Low' light.
It would have been nice tho... <img src="/forums/images/graemlins/notooth.gif" alt="" />
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: Low Fuel Light not Coming On [Re: 4WD22R] #666329 11/16/05 07:45 AM
kewlynx Offline
Nope, don't have 'em. Seems to me we didn't start having the fuel light available until 87-88; for non-SR5 at least.
I ran mine out on purpose just to see when I first got Ol' Blue (86). I believe that was what the 4th wire was for later on. That's a schematic trivia question. <img src="/forums/images/graemlins/smile.gif" alt="" />
**ubi apis- ibi salus**
Re: Low Fuel Light not Coming On [Re: kewlynx] #666330 11/16/05 04:12 PM
foxtrapper Offline
Well my 86 does have it, and it's shown in the owners manual. It doesn't start to flicker until I've got roughly a gallon of fuel left in the tank.
Re: Low Fuel Light not Coming On [Re: foxtrapper] #666331 11/17/05 04:44 AM
4WD22R Offline
Mmmmm well mine ran completly out(had to push it about a mile home good thing these 'yotas are so light) and it never came on...so I'm guessing I don't have one. Although there seems to be alot of places for idiot lights on the dash that don't do anything in mine.
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
--George W. Bush
Re: Low Fuel Light not Coming On [Re: TheToeCutter] #666332 11/17/05 05:10 AM
swamprunner Offline
My 85 didn't come with one and it came with the stupid lights. I put a sr5 cluster in there and them my gas gauge no longer worked. (Still haven't figured that one out yet) I can't tell you many times I've ran out of gas. So many I've lost count...but it doesn't matter cause I have a reserve on the back.
My brothers 87 sr5 came with the light. It never really was accurate though. sometimes you could would make it 20 miles before running out other times you make it 60 miles.
bottom line if you trust your gauge and think its right put gas in it when it reads E. The light aint worth sh1t
85 SR5 4runner....Too many hours of work put into it, Hacked, Beaten, and Still running after all I've put it through
87 Turbo Pickup...Bought Her for $500 put another $500 in her and she's running like a dream.
Re: Low Fuel Light not Coming On [Re: swamprunner] #666333 11/17/05 02:27 PM
G
Greg_Canada Offline
I know in mine, after 400KM it's time to look for the cheapest price gas station (have 10 litres left)
89 4Runner
Re: Low Fuel Light not Coming On [Re: 4WD22R] #666334 11/17/05 03:37 PM
foxtrapper Offline
You can check your truck to see if it's got one by counting the wires off the sending unit. Two and it doesn't. More than two, and it does. As the system is rarely activated, it's going to be prone to failure from inactivity.
Re: Low Fuel Light not Coming On [Re: foxtrapper] #666335 11/18/05 07:30 AM
V
Van91DSM Offline
My fuel gauge drops to E when she gets down past 3/4 tank too, so I start looking for fuel at 200 miles. One of these days I'll replace the sender. Anyone happen to know the price on a gauge sender unit for an '88 sr5 p/u?
'88 X-Cab 4x4
'00 4Runner
'91 Talon TSi
slacker Mitsu tech
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6439 MB (Peak: 0.7488 MB) Data Comp: Off Server Time: 2026-06-10 01:25:18 UTC
