Page 1 of 3 1 2 3
larger than stock oil filter for '90 v-6? #667799 11/18/05 09:34 PM
G
graeaglecrawler Offline OP
anybody running a larger filter at the stock location? part #'s would be appreciated.
'91 montero a/t cranked t-bars 31x10.5x15 212k
'90 toyota extra cab 320k v6 5 speed 31's 4x4
'99 expedition 17" alloys v-8 207k 4x4
'88 BMW 325iX 247k AWD
'59 Willys Jeep Koenig PTO winch and hardtop 28k
Re: larger than stock oil filter for '90 v-6? [Re: graeaglecrawler] #667800 11/19/05 12:24 AM
Snowtoy Offline
I am not sure if a larger one will fit in there. A longer one maybe, if it has the right threads. You could get one of the relocating kits that has an option for two filters from performance products.
How is the wheeling up above Gold Lake? I was up there back in July of '98 but I didn't get to explore much beyond the lake. Each year I have tried to schedule a run there, but my buddies always seem to want to go going somehwere else. Is the area still closed to 4x's in the winter?
Re: larger than stock oil filter for '90 v-6? [Re: Snowtoy] #667801 11/19/05 02:49 AM
G
just so happens i used to live in lake of the pines and then higgins corner and had a grass valley address at the latter. now i live in plumas pines and there are dirt roads that go on forever. i have done limited driving near gold lake mostly fishing and hiking, there is so many roads in this area as well as history( mostly gold history). they keep the road clear up to a new snow mobile staging area built in '00 but otherwise snow is 5' at that point up to maybe 10' plus. anyways i just got my '90 and am ready to change the oil. the previous owner gave me a "pure one, purolater" and it is the smallest filter i have ever seen.
Re: larger than stock oil filter for '90 v-6? [Re: graeaglecrawler] #667802 11/19/05 04:31 AM
Snowtoy Offline
It should be the right size, the 3.0 uses the same size filter as the 22r(4cyl.) engines. I have always used the Fram# PH3614. When you go to fill it, the 3.0 tends to take about 5.5 quarts for it to register on the dip stick. I find the easiest way to change the filter is to go in through the side above the frame rail. You basically do it blind, but it is easier than trying to get at from below.
I actually live about 7 miles from LOP. If you haven't been down this way in a while, the Higgens Corner area has been built up alot.
Re: larger than stock oil filter for '90 v-6? [Re: Snowtoy] #667803 11/19/05 04:50 AM
kyle-22r Offline
if the 3.0 does indeed take a compatible filter with the 22R, you can put a ford smallblock filter(fram PH8A, WIX 1515) on there if there's room. it has about twice as much capacity as a regular filter.
ps -- don't use fram.
'91 4x4 shortbed
22R-E, W56, the dd!
Re: larger than stock oil filter for '90 v-6? [Re: kyle-22r] #667804 11/19/05 06:02 AM
Adam F Offline
why
97 4R, stock, daily driver
Re: larger than stock oil filter for '90 v-6? [Re: Adam F] #667805 11/19/05 07:15 AM
A
allochris Offline
i use fram ph3614 too. why? (switching to castrol 5w30 for the winter!)
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/Camper
/33x10.5BFG-AT/Open 4:88/1.5"BJS/
+2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
Re: larger than stock oil filter for '90 v-6? [Re: Adam F] #667806 11/19/05 07:17 AM
1
1986xtracab Offline
not be repetitive but... i use a fram tg 3614?? so why?
Re: larger than stock oil filter for '90 v-6? [Re: graeaglecrawler] #667807 11/19/05 08:49 AM
Vonka Offline
I use the stock Tundra Oil filter:#90915-YZZD3.
It is a little taller than stock and you get the Toyota reliability.
88 4x4 22re
86 2wd 1-ton 22re
91 2wd 22re
Re: larger than stock oil filter for '90 v-6? [Re: Vonka] #667808 11/19/05 09:32 AM
ToyotaChris Offline
Not too sure bout how the 3.0L filter is, but I do know that only some filters have a back flow check valve.
the 3614 does, but the ph16 does not(this is the larger fram that will fit i think)
So in closing, you want a filter that has the backflow "valve" to hold the oil in the filter between eng. restarts to avoid cold startups.
Some filters dont have this valve cause the orientation of the filter ie.. right side up, allows gravity to hold the oil in.
My two cents
Watch Bruins Hockey
God Bless you guys and gals
1985 4Runner
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6388 MB (Peak: 0.7627 MB) Data Comp: Off Server Time: 2026-06-16 15:41:34 UTC
