2.3/2.6 Adjustable cam timing sprocket. #668761 11/21/05 04:16 PM
I
islandracer Offline OP
Hafa Adai!
I just pulled my home brew unit off my 2.3 motor. With the 2.6 sprocket I got from DVtrooper (Thanks!) I believe I have a center section unit that will work on both sprockets. This way you can have your original (2.3 or 2.6) sprocket fitted to this center section and Viola!.
Question is how many of you are interested in it and is there any machinists in the house or companies interested in fabing them up. I can have all the details/measurements worked out by the first week of Dec.
Any feedback is greatly appreciated. Thanks!
Shooootz!
Ton
B.Y.E. ~ Back Yard Engineering
Re: 2.3/2.6 Adjustable cam timing sprocket. [Re: islandracer] #668762 11/30/05 03:56 AM
Would this be centrifugal advance (desireable-with restraints) or bolt-and-go?
Re: 2.3/2.6 Adjustable cam timing sprocket. #668763 11/30/05 05:06 AM
mlclark Offline
Isuzu Moderator
This is about the cam timing sprocket. Not the dizzy.
Michael
Re: 2.3/2.6 Adjustable cam timing sprocket. [Re: mlclark] #668764 11/30/05 08:48 AM
maxwell417 Offline
Centrifugal advance are available for cam timing sprockets. But are more complicated, certainly above my skill level.
I had and adjustable cam timing sprocket on m VW Scirocco and Audi Coupe. The amount you can shift your motors torque band around is nearly unreal. Could take my VW from tractor like low rpm torque to high reving race motor feel. I bought one, and my friend made a copy.
Not intended as a real how to guide .... But if you have a spare sprocket, drill press and a lathe. It is pretty easy to make. On the lathe true up the inside of the sprocket, square corners are best. Make an aluminum plate to fit the center. Drill and tap the outside circumference, do the same on the spoke area of the sprocket. With a degree wheel mark off + and - 2 or 3 degrees, I can't remember now how many degrees now. Slot outside holes in the plate apropriately. Cut the spokes in the sprocket.
Curt B 89RS Calmini Header Delta Cam 33x10.5 BFG MTs & 90 Trooper 3.4 v6, SAS D44 ARB/Hobart 5.38s 35s my pictures
Re: 2.3/2.6 Adjustable cam timing sprocket. [Re: maxwell417] #668765 11/30/05 09:17 AM
mlclark Offline
Isuzu Moderator
Seriously? That's pretty darn cool.
Michael
Re: 2.3/2.6 Adjustable cam timing sprocket. [Re: mlclark] #668766 11/30/05 09:43 AM
maxwell417 Offline
Yup ... They were way to expensive for my VW/Audi budget back then.
http://thorin.adnc.com/~figf/
Re: 2.3/2.6 Adjustable cam timing sprocket. [Re: maxwell417] #668767 12/03/05 02:54 AM
Great link maxwell417. I read about these some years ago and would like (might, even) to build one for our two 2.6 Troops. So much exact precision as well as durability required to prevent toasting engine internals. Lots O' racers use slotted sprockets on a 3 bolt adapter, but I've always thought the centrifugal advance would cover a wider range of driving conditions. Again, great link...Thanks!
Re: 2.3/2.6 Adjustable cam timing sprocket. [Re: islandracer] #668768 12/03/05 03:02 AM
Back to your original post, yes, I'd be most interested in the specs for this adapter, as well as a photo or 2. I kept a couple of my lathes and a mill (and some other machines) for tinkering and building gadgets. I would enjoy such a project.
Re: 2.3/2.6 Adjustable cam timing sprocket. #668769 12/03/05 03:08 AM
Troopersphere Offline
Interesting... Since the diz is driven from the back of the cam, how would something like this be set up to compensate for that ? Or, would the ignition timing necessarily change as the cam timing did ? I'm confused...
C/YA!
Jeff
'88 Trooper
2DR LWB 4ZE1 5SP
bone stock DD
Re: 2.3/2.6 Adjustable cam timing sprocket. [Re: Troopersphere] #668770 12/03/05 04:16 PM
I'd be interested in seeing some specs and a photo or two as well. Sounds like an interesting experiment. I've seen or heard about the rally guys running them and wouldn't mine fooling around with one myself.
John <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 2.407s Queries: 16 (0.006s) Memory: 0.6306 MB (Peak: 0.7535 MB) Data Comp: Off Server Time: 2026-07-13 04:52:10 UTC
