Page 8 of 23 1 2 6 7 8 9 10 22 23
Re: good bye saggy rear [Re: Seattlegti] #669130 12/07/05 11:04 PM
samron333 Offline
Has this/can this be done on the front end as well?
84 Longbed, 31 Mud Terrain SXT, rest is stock
CBR 1000, for when i need to hit sixty in less than thirty seconds
Re: good bye saggy rear [Re: samron333] #669131 12/07/05 11:08 PM
4Crawler Offline
Assuming a stock front leaf springs and steering, probably won't be able to uses coils like that. Hardly any clearance for steering and very little room to the bump stops for any sort of spring. Perhaps you would use a coil helper spring on the shock or an air shock if there is a suitable one that would fit. Stock shock mounts are not terribly robust, so they might fail under the added load. New lift springs would likely be the best option.
Re: good bye saggy rear [Re: 4Crawler] #669132 12/08/05 01:05 AM
Red_Chili Offline
Toyota Section Staffer
I would think more stable too. Pretty important in the front.
-Bill
Re: good bye saggy rear [Re: samron333] #669133 12/08/05 01:40 AM
airshox made for a 4 runner rear, i believe 94 or so,
fit perfectly on the front of my 88 with trailmaster type 4" ifs lift and get near 12" travel
plus hav all the advantages of hyjackers
adj. lift
superior air ride
$60 cost
bolt on install
i hav no upper bumpstops and use the stock mounts
nothing's bent yet
i've bottomed it plenty
simply amazing
i had edelbrocks b4 that
hyjackers hav WAY superior ride
Re: good bye saggy rear #669134 12/08/05 03:05 AM
1
1986xtracab Offline
where they front or rear springs?
Re: good bye saggy rear [Re: 1986xtracab] #669135 12/08/05 05:37 AM
im assuming this is directed at me?
they are rear springs from the TJ. the TJ fronts are taller and have a heavier spring rate. I have a set of those too. the fronts have the same "neck down" at the bottom and the tops are open enough to fit over the "landing pad" but you would have to cut a lot off the top, but might be an option if you want more lift.
Re: good bye saggy rear #669136 12/08/05 02:50 PM
1
1986xtracab Offline
Thanks, I Think I found some locally pretty cheap!
FJ80 springs? #669137 12/10/05 12:40 AM
Frank Torres Offline
Very Cool!
Now I know what to do with my leftover coils from the FJ80.
The front coils might work better than the rears, they are smaller in diameter.
Napoleon047, how hard was it to cut the coil springs from the tj?
thanks...
1991 FJ 80 Land Cruiser for fun.
1998 GS300 for the wife
1998 GS400 for me
1991 Supra SOLD
1986 4Runner 335k miles-22re EB inside.SOLD
Re: FJ80 springs? [Re: Frank Torres] #669138 12/12/05 06:53 PM
TexJeff87 Offline
So I went to my local 4WP and got some throw-away TJ coils for free today.
Merry fab-mas to me...
If Mad Max had a 4runner...
Re: good bye saggy rear #669139 12/12/05 11:13 PM
1
1FastSS Offline
stock rear TJ coil with the top cut off a bit. fits perfectly, and a nice 2" lift to fix the saggy butt on my brother's 87 4runner. no fabrication necessary.
total cost: $5 for some 'junk' TJ coils
great idea ZUK!
I'm interested in this as well....Is this what I need?
eBay
Thanks.......
- Daily Driver - 2004 Corolla
- Off Road - 1992 Pickup SR5 3.0L 4x4
- Fun - 2001 Camaro SS (320 RWHP/330 RWTQ)
http://community.webshots.com/user/1fastss
PHP: 7.4.33 Page Time: 0.008s Queries: 14 (0.005s) Memory: 0.6468 MB (Peak: 0.7530 MB) Data Comp: Off Server Time: 2026-05-29 21:12:51 UTC
