Re: good bye saggy rear
[Re: Seattlegti]
#669130
12/07/05 11:04 PM
Has this/can this be done on the front end as well?
84 Longbed, 31 Mud Terrain SXT, rest is stock CBR 1000, for when i need to hit sixty in less than thirty seconds
[Re: samron333]
#669131
12/07/05 11:08 PM
Assuming a stock front leaf springs and steering, probably won't be able to uses coils like that. Hardly any clearance for steering and very little room to the bump stops for any sort of spring. Perhaps you would use a coil helper spring on the shock or an air shock if there is a suitable one that would fit. Stock shock mounts are not terribly robust, so they might fail under the added load. New lift springs would likely be the best option.
[Re: 4Crawler]
#669132
12/08/05 01:05 AM
Toyota Section Staffer
I would think more stable too. Pretty important in the front.
-Bill '87 4Runner w/ '96 5VZ-FE, 'Red Chili II' '97 Taco XtraCab 3RZ-FE, 'BlackBean' TLCA # 13257, Rising Sun 4x4 Club Land Use Coordinator "He who stops being better stops being good." -Oliver Cromwell
[Re: samron333]
#669133
12/08/05 01:40 AM
airshox made for a 4 runner rear, i believe 94 or so, fit perfectly on the front of my 88 with trailmaster type 4" ifs lift and get near 12" travel plus hav all the advantages of hyjackers adj. lift superior air ride $60 cost bolt on install i hav no upper bumpstops and use the stock mounts nothing's bent yet i've bottomed it plenty simply amazing i had edelbrocks b4 that hyjackers hav WAY superior ride
#669134
12/08/05 03:05 AM
where they front or rear springs?
[Re: 1986xtracab]
#669135
12/08/05 05:37 AM
where they front or rear springs? im assuming this is directed at me? they are rear springs from the TJ. the TJ fronts are taller and have a heavier spring rate. I have a set of those too. the fronts have the same "neck down" at the bottom and the tops are open enough to fit over the "landing pad" but you would have to cut a lot off the top, but might be an option if you want more lift.
#669136
12/08/05 02:50 PM
Thanks, I Think I found some locally pretty cheap!
FJ80 springs?
#669137
12/10/05 12:40 AM
Very Cool!
Now I know what to do with my leftover coils from the FJ80. The front coils might work better than the rears, they are smaller in diameter.
Napoleon047, how hard was it to cut the coil springs from the tj?
thanks...
1991 FJ 80 Land Cruiser for fun. 1998 GS300 for the wife 1998 GS400 for me 1991 Supra SOLD 1986 4Runner 335k miles-22re EB inside.SOLD
Re: FJ80 springs?
[Re: Frank Torres]
#669138
12/12/05 06:53 PM
So I went to my local 4WP and got some throw-away TJ coils for free today.
Merry fab-mas to me...
If Mad Max had a 4runner...
#669139
12/12/05 11:13 PM
stock rear TJ coil with the top cut off a bit. fits perfectly, and a nice 2" lift to fix the saggy butt on my brother's 87 4runner. no fabrication necessary. total cost: $5 for some 'junk' TJ coils great idea ZUK! I'm interested in this as well....Is this what I need? eBay Thanks.......
