Re: good bye saggy rear
[Re: Adam F]
#669160
12/18/05 11:56 PM
Tell you what...I'm only doing this once. I'm about to order a u-bolt flip kit for the rear. I have it flipped now, but the plates are some I scabbed off of an S-10. As I have to take it apart to remove the block, and you ain't supposed to re-use ubolts, I'll weld a dooma-hicky on the plate for coil retention, and post some pics when it's done. Adam, go ahead and get some front TJ coils. This should be uber-easy... <img src="/forums/images/graemlins/kewl.gif" alt="" />
If Mad Max had a 4runner...
[Re: Kona]
#669161
12/19/05 12:37 AM
I just thought I might chime in here once again. It's been almost three weeks since ZUK put my springs in for me and I'm still happy as a clam. No settling on the springs yet and even with a full load of tools and a bunch of ply out the back I still haven't dropped the truck all the way back down to the overloads.
It seems that every time I pull into a hardware store or lumberyard I get someone asking about the lift. thanks for chiming in Kona! Sorry for the attention you're getting <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: ZUK]
#669162
12/19/05 02:34 AM
yesterday, i helped my brother load up his 4runner to head home for winter break with everything. had his 4runner packed full of clothes, microwave, computer, TV etc. with the TJ coils, it wouldnt hit the overloads and still rode great! ![[Linked Image]](http://web.missouri.edu/~pje3k5/coil/DSCF0144%20(Small).JPG)
[Re: ZUK]
#669163
12/19/05 09:38 PM
![[Linked Image]](http://i12.photobucket.com/albums/a206/sittingwolf/Pc130006.jpg) Before pic; Rim to fender well=16.50"
#669164
12/19/05 09:44 PM
#669165
12/19/05 09:45 PM
#669166
12/19/05 10:06 PM
The previous 3 pic's are mine, I'm not very handy with the copy & paste thing. If I tried to ad text the pic wouldn't come out, and I wasn't sure how to get them all in one post.
The 1st and third are before and after, the 2nd one is when I had to expand the leafpack about an inch to get the coil in there.
In the before pic the rim to fender well measurement is 16.50". In the after pic the rim to well measurement is 18.25", giving me a lift of 1.75" which is IDEAL <img src="/forums/images/graemlins/smile.gif" alt="" /> (you da man Zuk) <img src="/forums/images/graemlins/kewl.gif" alt="" /> as I was hoping for something between 1.5" & 2".
The entire proceedure went well and was just as described, took me about 4.5 hours (I'm 59 and move kind of slow) <img src="/forums/images/graemlins/sleeping.gif" alt="" />
Haven't driven it yet, waiting for the pain pill to kick in. <img src="/forums/images/graemlins/shiner.gif" alt="" /> but I don't have any reason to believe it's not going to ride much better than before, when I bounced the bed it was softer than just the spring.
#669167
12/19/05 11:04 PM
What springs did you use? Are those blocks under the springs welded together?
[Re: Adam F]
#669168
12/20/05 01:36 AM
Yep...the height on Geriatric was about 4" higher than stock dimensions....so I fabbed up two 2 inch blocks for each side. The blocks are welded but not "excessively" such that a block could be removed. I can post a pic later of what the entire assembly looks like......unless Chris beats me to it.
Looks nice Chris! <img src="/forums/images/graemlins/kewl.gif" alt="" /> Any install issues? PITA trying to squeeze them in there or did the jack on the leafs work good? ZUK
ps---pretty good for a 59 year old <img src="/forums/images/graemlins/kewl.gif" alt="" /> I'm a tender 49....still.
ya....you might notice a better ride....less inter-leaf sliding resistance. Your leafs will likely never sag....get back to me in 10 years <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: ZUK]
#669169
12/20/05 04:04 AM
The entire process was straight forward, the jack on the leafpack was easy, but I'd suggest anyone doing it use caution because of the angled surfaces your working with.
ya....you might notice a better ride....less inter-leaf sliding resistance. Your leafs will likely never sag....get back to me in 10 years <img src="/forums/images/graemlins/kewl.gif" alt="" /> [/quote]
It also had the extra side effect of leveling the rear of the truck, those AllPro's weren't wearing evenly and it was listing to port a little.
I forgot to take a pic of the coils before I installed them Zuk, so you can post up the pic's if you please. Btw, I'm Fred
