Page 14 of 23 1 2 12 13 14 15 16 22 23
Re: good bye saggy rear #669190 12/25/05 06:40 AM
ZUK Offline OP
from Napolean....
hey ZUK, how much would you want for just your lower coil mounts? this would be for people who want to do the TJ coils but dont like the bumpstop idea or have cracked/missing bumpstops. the bottom of the TJ coils fit perfectly over 2" square tube (im not sure what size you are using in yours: 2.5" square?)
ok...I took some notes and I can make a pair of lower mounts that will work great....they will not be self capture because you say they seem to stay in place. It also probably means a coil compressor is not needed because the coil does not get lifted up and over the tall rubber bump stops. How about $60 to cover materials and shipping in the 48 states? But you must post pics of how it went.
mostly stock
Re: good bye saggy rear [Re: ZUK] #669191 12/26/05 02:42 AM
ZUK Offline OP
made up 1 lower set for TJ coils.....any takers for these?. These took me over an hour in cut/clean/drill/weld. ZUK <img src="/forums/images/graemlins/kewl.gif" alt="" />
mostly stock
Re: good bye saggy rear [Re: ZUK] #669192 12/26/05 03:07 AM
Rauch_Off_Road Offline
just an idea but it would be cool if you could combine them with a U-bolt flip kit that captures the spring. Might make for a really decient off-road/DD option for gen 1 runners and some trucks.
(aka suprathepeg, aka Sean)
Re: good bye saggy rear [Re: ZUK] #669193 12/26/05 06:21 PM
matts Offline
My gut feeling says the "Napo coil" will about work for you(see pic below)....
I'm sure you went over this earlier in this thread, but it's gotten to big to re-read casually. What is a Napco coil? -- Matt
'89 4runner SR5, 3.0, auto (fun)
'93 xtra cab, dlx,3.0, 5spd (work truck)
Re: good bye saggy rear [Re: matts] #669194 12/26/05 08:03 PM
ZUK Offline OP
Happy New Year Matt-
I'm calling this the Napo coil....a TJ coil slapped over the rubber snubber. It don't get any cheaper and easier than this smile The pic above with my black painted mounts allows the TJ coil a better fit. I can self-capture the bottom mount if needed too.
The ZUK coil are the dual red ones....or the center mounted single version <img src="/forums/images/graemlins/cheers.gif" alt="" />
mostly stock
Re: good bye saggy rear [Re: ZUK] #669195 12/26/05 09:13 PM
ZUK Offline OP
OK.....I trimmed the corners and the lower mount will slip right in the middle of a "flip-over".....a bolt can secure it at each end(see the 5/16" drilled holes)
mostly stock
Re: good bye saggy rear [Re: ZUK] #669196 12/27/05 01:29 AM
WOW! i dont check the board for a couple days and ive got a coil setup named after me, and ZUK has developed a lower coil mount and improved upon it!
i like it ZUK <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: good bye saggy rear #669197 12/27/05 03:27 AM
ZUK Offline OP
improved it more....and more.... <img src="/forums/images/graemlins/smile.gif" alt="" />
feel sorry for the dial up guys....wait a sec. I'm one of them <img src="/forums/images/graemlins/scared.gif" alt="" />
mostly stock
Re: good bye saggy rear [Re: ZUK] #669198 01/02/06 06:38 AM
ZUK Offline OP
The middle set is heading to Kentucky....got 2 sets left for those with saggy Runners. <img src="/forums/images/graemlins/cheers.gif" alt="" /> Happy New Year. ZUK
mostly stock
Re: good bye saggy rear [Re: ZUK] #669199 01/10/06 03:33 AM
Staceman Offline
Keeping the thread alive! My truck was "ZUKified" again today. Here's a before pic with my sagging "custom" leaf springs, part Toyota, part Mazda. Soft, and any weight in the rear, spare tire, tools, hi-lift, camp gear etc. throws the rear end down. Notice the springs almost reversed arched sitting static.
Here's ZUK under my truck (again) <img src="/forums/images/graemlins/wink.gif" alt="" />
After 4 hours. My u-bolt flip plates needed "un-modified", to re-modify for the spring captures.
Nice arch, 2" lift, super-smooth ride, like stock new, and I noticed alot less body roll in the corners.
This Sunday is a Crown King trail ride here, so we'll see how they do on a 3 1/2 trail. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Keep you posted and I'll check back later.
Staceman
PHP: 7.4.33 Page Time: 1.598s Queries: 14 (0.006s) Memory: 0.6544 MB (Peak: 0.7648 MB) Data Comp: Off Server Time: 2026-05-29 22:46:42 UTC
