Page 10 of 17 1 2 8 9 10 11 12 16 17
Re: R/C tube buggy [Re: TexJeff87] #669383 12/16/05 02:56 AM
Talon84X4 Offline
[Img]http://img162.imageshack.us/img162/7260/riverflex5ot.jpg[Img]
Scorpion flexing on some rocks in the front yard, no it wasn't just put in that position.
Doesn't look like i did it right, so here's the link...haha, if that works right too
http://img162.imageshack.us/my.php?image=riverflex5ot.jpg
Re: R/C tube buggy [Re: Talon84X4] #669384 12/16/05 06:36 AM
onebadtrooper Offline OP
Hey Adam, What do you think of this esc?? I have a chance to get one of these in a trade.
web page
The guy from clodmodracing is interested in my RC18T I have for sale
Re: R/C tube buggy [Re: onebadtrooper] #669385 12/16/05 07:59 PM
DentedTacoma Offline
Where would I go to see what parts I would need to build an RC Crawler myself? Maybe an indication of the difficultyu would be helpful as well. I believe that I can make the body and frame but then the motor and suspension I would have no idea. Help?
98' Toyota Tacoma SR5
Manual Xtra Cab, Slight Lift
Maine Rules!
Re: R/C tube buggy [Re: DentedTacoma] #669386 12/16/05 08:39 PM
This is by far the best place to go for r/c rockcrawling
RC Rock Crawlers
Re: R/C tube buggy [Re: onebadtrooper] #669387 12/16/05 11:25 PM
Adam F Offline
Looks good. One thing I diddnt see specs for is the BEC which is how much current it feeds the servos. Check into it and figure out what it has, its important. With a crawler you want AT LEAST 2 amps BEC. Anything less will not be good. The Tekin I have has a 5 amp BEC and its only $80. Thats what I reccomend.
EDIT...after further searching, I would not reccomend this ESC. On associated's website, it says it only has a 5 volt BEC, adn doesnt even list the amperage, so I'm assuming its low. You want a 6 volt BEC. WIth a 5 volt, the servos will not get the voltage they need to put out the most torque available. You will have weak steering, and if the amperage is low, glitchy controls, and it may not even work, and you will end up having to run a separate battery pack to power the servos.
Id just bit the bullet and buy a Tekin Rebel II.
97 4R, stock, daily driver
Re: R/C tube buggy [Re: TexJeff87] #669388 12/16/05 11:27 PM
Adam F Offline
So Adam, how fast does it go in hi gear? You got the 1:18 one, right? Or the 1:6th?
Maybe a slow jogging/fast walking pace. Faster than you'll ever need for crawling, which is what this is meant for.
I have the 1/18.
Re: R/C tube buggy [Re: onebadtrooper] #669389 12/16/05 11:29 PM
Adam F Offline
Man, I'll tell you what, this little Nylint is a ton of fun! For only $40, it rocks! I couldnt be happier. For anyone who is thinking about getting into this hobby, and might not be sure they would like the slow pace, I would HIGHLY reccomend buying one of these. They are great right out of the box. Only thing I have done is cut off 4 coils off of the springs. It could use some bigger tires, but I don't really want to change it a whole lot. It's more of a challenge this way. I have a big crawler to make it look easy!
I moved the rocks to the corner and added the rocks I picked up today. May not look like a lot of rocks, but its quite a bit. Lots of fun for the Nylint. But I'll add a ton more shortly.
Re: R/C tube buggy [Re: Adam F] #669390 12/16/05 11:35 PM
Talon84X4 Offline
I second, actually on my way to go buy another one <img src="/forums/images/graemlins/kewl.gif" alt="" />, this time for my little brother, after i replace my fuel pump right now.
'84 PU low & slow
Central Valley Crawlers
Re: R/C tube buggy [Re: Adam F] #669391 12/16/05 11:40 PM
Cool, All that I've found so far is that it has 5volts BEC, I'm still looking how many amps...
Re: R/C tube buggy [Re: onebadtrooper] #669392 12/16/05 11:46 PM
Adam F Offline
Even if it has a million amps at 5 volts, your not going to get the full potential of your servos. You need every ounce of power from your servos to turn the wheels.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6566 MB (Peak: 0.7629 MB) Data Comp: Off Server Time: 2026-06-07 06:13:03 UTC
