Re: power steering hose torque spec
[Re: taro]
#670202
12/08/05 05:51 PM
I'm in the middle of the same job and the sensor is frozen in the old high pressure hose - does anyone know where i can get one?
#670203
12/09/05 03:02 AM
Don't know about where you can get one, but I bought a big honkin vice (for me at least) to rebuild the power steering pump. I just put the hose in the vice and I was able to twist the sensor off. Good luck.
#670204
12/09/05 06:15 AM
Can you cut/grind the old hose enough to loosen the the sensor? If you cut a groove in the outer threaded part not quite down to the threads and smack the groove with a wider chisel, it will often 'spring' the outer threaded piece apart, freeing up the inner threaded part.
Randii
[Re: randii]
#670205
12/09/05 04:15 PM
good idea - I can try that...
the sensor itself has a cracked cover so I'm still checking around for a replacement. I can fix the cover if I need to.
I have it soaking with penetrating oil on the inside and I'm going to torch it over the weekend -if that all fails I'll start grinding. It threads into a piece of square stock and grinding one side off might work - hard to get a hacksaw in place since the body of the sensor is in the way. Now if I had a milling machine...
#670206
12/28/05 05:49 AM
Hi, I'm having the same problem w/ a stuck sensor in the old power steering pressure hose. Were you able to find a replacement sensor.
My local Kragen can't find the part in the computer. I managed to break the wires leading out of the sensor while loosening the lower fitting on the hose, so I'm gonna need a new one either way. Any info or advice would be hugely appreciated. -Mike
#670207
12/28/05 01:39 PM
Jerry Lemond jlemond@bellsouth.netHe'll get you squared away. He probably has them in stock.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake 1989 Trooper 2.6 auto 1989 I-Mark RS DOHC 1.6 1991 Stylus XS DOHC 1.8
PHP: 7.4.33 Page Time: 0.017s Queries: 15 (0.013s) Memory: 0.6105 MB (Peak: 0.6784 MB) Data Comp: Off Server Time: 2026-11-19 05:30:14 UTCValid HTML 5 and Valid CSS
