Transmission failing ? #670336 11/25/05 10:41 PM
F
fidgit Offline OP
I hope you all can help with this, I have been having a problem with my transmission when ever I down shift it will not go into gear and grinds like crazy it started to do this only when I downshifted into second but now it is doing it on the up shift and as well as third gear so it is getting worse.
I have a 03 Rubicon 5 speed with to many miles on it. No lift  only modds so far have been rock sliders and skid plates.
Re: Transmission failing ? [Re: fidgit] #670337 11/26/05 02:00 AM
Change the Fluid!!!!
Re: Transmission failing ? #670338 11/26/05 05:19 PM
F
fidgit Offline OP
Ok I changed the fluid this morning. I have only gone maybe 20 miles but it is still doing it there was water in the transmission.
Thanks Sunder maybe it will get better.
Re: Transmission failing ? [Re: fidgit] #670339 11/26/05 06:10 PM
BigJim Offline
Ok now change it again! You prolly still have water in there!
Re: Transmission failing ? [Re: BigJim] #670340 11/26/05 06:25 PM
F
fidgit Offline OP
Sweet only 18.80 per qaurt for Jeep good thing I am made of money or this would really be bad <img src="/forums/images/graemlins/scared.gif" alt="" />
I bet this had nothing to do with it. [Linked Image]
Re: Transmission failing ? [Re: fidgit] #670341 11/26/05 06:50 PM
Sc0rp10n Offline
Perish the thought.
But yeah it may take a few changings to get all the h20 out.
Good Luck
Nick
2000 XJ Classic - Classically a POS
1994 Isuzu Amigo XS -Sold
1972/3 CJ5 Glass body, 5" lift 34's. 5 years of work coming to an end.
Re: Transmission failing ? [Re: fidgit] #670342 11/26/05 06:54 PM
Mudlover27 Offline
WOW Fidgit, your asking for it, I hope you sealed up everything i.e. axles, elec, Trans and T case vents extened,, if not I wouldn't expect that 03 rubi to last too much longer taking dep water like that!!!
But it is fun going trough it !!!!!! <img src="/forums/images/graemlins/lol.gif" alt="" />
98 wrangler 2.5l 3 inch rustys, 2 inch body, 33X12.5 MTR's DETROIT LOCKER, 4.88 gears, moser axles, Dana 44 (rubicon housing)
Re: Transmission failing ? [Re: Mudlover27] #670343 11/26/05 07:08 PM
F
fidgit Offline OP
Oh yeah it was fun. Most everything is sealed I moved all the axle vents up onto the roll bars over my head not that they should ever need to be that high up <img src="/forums/images/graemlins/evil.gif" alt="" />
Ok well I will flush her out again.
Re: Transmission failing ? [Re: Mudlover27] #670344 11/26/05 07:19 PM
F
fidgit Offline OP
Also what you can't see in that pic was that I made a bad turn in the river and had to go around and big rock. The only thing I could do at the time was hit the gas and try to get over to the right as fast as I could. I had planned to go into the river just not that side. Trust me I ripped most of the cloth of my seat doing that. But in the end it was allot of fun you just can't see the hart attack I am having. <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: Transmission failing ? [Re: fidgit] #670345 11/26/05 08:57 PM
You might want to flush it a couple times with the cheapo kregan stuff that's the right viscosity then put in the expensive stuff. Just put it in, take it easy for 10 miles, then drain it and do it again. The only difference between the cheapo stuff and the good stuff is the additives. So if you have a little bit of the crappy stuff with no water, it is a lot better than the expensive stuff with water.
PHP: 7.4.33 Page Time: 0.034s Queries: 16 (0.010s) Memory: 0.6327 MB (Peak: 0.7398 MB) Data Comp: Off Server Time: 2026-07-14 21:40:39 UTC
