Page 5 of 8 1 2 3 4 5 6 7 8
Re: Bad idle after warm up??? [Re: mlclark] #671053 12/24/05 09:00 PM
bob large Offline OP
The only screw I have adjusted is the air bypass screw.
The other ones I havenÆt touched.
And ya if you could get the adjustment figures I would appreciate it. I don't see anything about it in my Haynes.
I just took it for another test run. <img src="/forums/images/graemlins/smile.gif" alt="" /> Pepy! <img src="/forums/images/graemlins/drunk.gif" alt="" />
Re: Bad idle after warm up??? [Re: bob large] #671054 12/24/05 09:55 PM
Don_W Offline
Not familiar with the Amigo, (or my own trooper, for that matter) but on the trooper both the AAV and the coolant temp sensor bypass the throttle, could they be stuck open?
Re: Bad idle after warm up??? [Re: Don_W] #671055 12/24/05 09:59 PM
well the aux air valve on my 2.6 is brand spanking new.
but i'm not sure about the "coolant temp sensor bypass"
Steve C
Re: Bad idle after warm up??? [Re: bob large] #671056 12/24/05 10:38 PM
Troopersphere Offline
But I still have an under lying problem. It seams to idle fine but when youÆre driving it and you let off the throttle and you push in the clutch the RPM bounces from 1000 to 1500 RPM. Like itÆs advancing the engine, then back, then advancing, exc.
Steve, this symptom sounds to me like you may have a problem with the temp switch that's mounted on the top of the thermostat housing. There's a hose that runs from the air intake tube to this switch, and from there to the common chamber on the intake manifold. If this switch opens you will get that idle "surging" that you describe. The ECM is monitoring the RPM of the engine. If it sees the RPM going over around say 1600 RPM, AND the Throttle Position Switch is on IDLE, the computer will enter the FUEL CUT MODE (cutting off fuel) until the idle goes back to around 1200 RPM, when it turns the fuel back on again.
It does this only when you are driving ???
What about if you pull off the road when it starts this, and just let it idle ?
Does it stop doing this the instant you crack the throttle open again ? (just enough to get the TPS idle switch open?)
It could also indicate an overheating condition, so make sure that you've "burped" any air bubble out of the cooling system. (Does the heater work OK ?)
One thing you can try that might isolate the problem to that switch: Pull the hose from the air tube to the switch and plug it. Plug the hole in the air tube. See if the problem goes away.
If you have a spare one of those switches kicking around, try a different one.
I know that you know you DON'T want to overheat that brandy new motor, so make absolutely sure your cooling system is functioning properly! (Is the T'stat installed correctly?)
[edit] Check out this article
Article about surging idle
C/YA!
Jeff
'88 Trooper
2DR LWB 4ZE1 5SP
bone stock DD
Re: Bad idle after warm up??? [Re: Troopersphere] #671057 12/24/05 11:37 PM
this sound like just what its doing. <img src="/forums/images/graemlins/kewl.gif" alt="" /> i'll check it out.
Steve C
Re: Bad idle after warm up??? [Re: bob large] #671058 12/25/05 09:07 PM
well i changed it out and no change.
Steve C
Re: Bad idle after warm up??? [Re: bob large] #671059 12/25/05 09:44 PM
mlclark Offline
Isuzu Moderator
Bob-
I knew it was around here somewhere.
LINK
It will get you headed in the correct direction.
Michael
Re: Bad idle after warm up??? [Re: mlclark] #671060 12/25/05 10:04 PM
by the way 19 inch of vacume at idle. now that i set the timming.
Steve C
Re: Bad idle after warm up??? [Re: bob large] #671061 12/26/05 04:13 PM
i set the TPS and no change.
any other ideas?
Steve C
Re: Bad idle after warm up??? [Re: bob large] #671062 12/26/05 05:30 PM
Lemmee ask some questions again, answers to these could help diagnose... I'm beginning to think maybe there's a problem with the Vehicle Speed Sensor. Your SPEEDO is working properly, yes ?
It does this only when you are driving (vehicle in motion)??? and if you pull off the road when it starts this, and just let it idle ?
Are you ABSOTIVELY POSILUTELY SURE that she's not got an air bubble in the cooling system ?? and running hot ?? and that the T'STAT is installed correctly ? (i.e. air bleed hole UP, facing correct direction?)
I would still try the following test, easy to do. If it still acts up with these hoses plugged, then it's certainly not related to that temp switch (I'm still not sure it isn't, even though you changed it).
Does your truck have A/C ? if so, are the hoses to the fast idle solenoid routed properly ?
C/YA!
Jeff
'88 Trooper
2DR LWB 4ZE1 5SP
bone stock DD
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6518 MB (Peak: 0.7591 MB) Data Comp: Off Server Time: 2026-06-22 07:34:19 UTC
