Re: Converting to Propane?
[Re: fasteddy]
#671100
12/09/05 05:35 PM
Up in Canada EH there are lots of propane powered vehicles. Newer fuel injected ones too. It is a great fuel and storage has to be the set back if there is one. In newer vehicles the fuel system is turned off and a Voodoo box (I like that word <img src="/forums/images/graemlins/kewl.gif" alt="" />) is used to control emission parameters to keep your engine light out. I don't recommend dual fuel as the two fuels are quite different and require different timing settings. Not too much room for two fuel cells in a 2dr Montero/Raider anyhow. It is written that if the technology was around one hundered years ago to put propane under pressure into cylinders we would not be using Gasoline today.<img src="/forums/images/graemlins/cheers.gif" alt="" />
87 Dodge Raider w/mits 2.3 Turbo Diesel 5 speed
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.5861 MB (Peak: 0.6419 MB) Data Comp: Off Server Time: 2026-06-12 14:50:14 UTCValid HTML 5 and Valid CSS
