Front Bumper Mounts #671450 11/28/05 10:38 PM
Zubicon Offline OP
I'm getting ready to ditch the Olympia front bumper that I have for a DIY. Anyone have any pics as to how some of the aftermarket are mounting theirs? Mine will be fairly close to the style of Advanced frameworks and Hansen Enterprises if that helps.
Re: Front Bumper Mounts [Re: Zubicon] #671451 11/30/05 10:22 PM
Paddler Offline
No help.......not one........come on show some love. <img src="/forums/images/graemlins/baby.gif" alt="" />
1995 Honda Passport;
Some people wait a life time for their ship to sail in, while others simple grab the oars and begin paddling
Yours truely
http://www.zutah.com
Re: Front Bumper Mounts [Re: Zubicon] #671452 12/01/05 12:21 AM
Mudlover27 Offline
I Don't know that comp design but it should go right int he stock location just like your olymp, Ie to the frame rails and the crossmember , via some tabs welded to the bumper
98 wrangler 2.5l 3 inch rustys, 2 inch body, 33X12.5 MTR's DETROIT LOCKER, 4.88 gears, moser axles, Dana 44 (rubicon housing)
Re: Front Bumper Mounts [Re: Paddler] #671453 12/02/05 06:47 PM
Dan-H Offline
build it so it mounts like the stock bumper mounts, just use 3/16" steel.
01 TJ sport
99 4Runner SR5 ( wifes ) Stock with Electric locker for serious grocery getting !!!
Re: Front Bumper Mounts [Re: Dan-H] #671454 12/04/05 07:06 PM
Zubi, after looking at the fine job that you did on your rear bumper why would you have any questions as to how to build the front bumper. Just do like Dan-H said and get it done!!!
Re: Front Bumper Mounts [Re: Zubicon] #671455 12/04/05 07:13 PM
Post some pics of the front bumper when it is done. I may have to hire you to build me a nice set of everything. I saw some similar rocker guards to the ones you made, I think they were going for $4?? so you made out well doing it yourself like you said rather than paying over $400 <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Front Bumper Mounts #671456 12/04/05 09:27 PM
Zubicon Offline OP
I'm just not sure of utilizing just the stock mounts for something that has a 9,500 lbs sheer potential. Actually 19,000 lb sheer potential when I' in a "snatch block" scenario.
Re: Front Bumper Mounts [Re: Zubicon] #671457 12/05/05 12:03 AM
BigJim Offline
I am not aware of them EVER failing!
Re: Front Bumper Mounts [Re: Zubicon] #671458 12/05/05 11:16 PM
Dan-H Offline
The stock mount is three (3) 1/2 inch bolts per frame rail.
I don't have my engineering notebook handy, but IIRC, the rating of one (1) 1/2 inch grade 5 bolt in single shear is over 10K lbs, and one (1) 1/2 inch grade 8 bolt in single shear is over 12K lbs.
12K x 6 = 72K lbs if you can evenly distribute the load. across both frame rails before the bolts fail.
If the pull you are talking about is from a winch, look closely at the small bolts that warn supplies with their 9500 lb winches. and they are only grade 5.
01 TJ sport
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6226 MB (Peak: 0.7044 MB) Data Comp: Off Server Time: 2026-10-22 18:15:10 UTC
