rear disc conversion
#671790
11/30/05 04:13 AM
This is for my 1989 buildup that I'm doing. I called Downey off-road today and got a price of $139.00 for the caliper brackets. Is there another company that is able to sell just the brackets? I thought I've seen them somewhere.
Re: rear disc conversion
[Re: hdrisc]
#671791
11/30/05 04:35 AM
prolly can get just the brackets from front range offroad. but your still going to need axle shafts.
Welding and Fabrication Engineer 2003 taco V6 ext cab sr5 1988 Toyota Pickup V6(totaled)
[Re: hdrisc]
#671792
11/30/05 05:13 AM
SKY sells them, much cheaper than the downey brackets, and they also sell everything else you need for a rear-disc convo. SKY Click on Toyota then SUSPENSION... scroll down a bit...
89 4Runner 3" BL, M/T locks, 33"bfg mt, bilstein, Kayline, tubebumper, toyotafiberglass panels TBI: Elocker,3.4 w/ORS,b+b,S2Sstg2cams,arias pistons,P+P intake,TRDs/c,URDpullies+7th,downey headers,MAPECU2,WEGO WB, SupraMAF,walboro255,stg4clutch, EPaOo2 sim
[Re: CraShYota]
#671793
11/30/05 06:05 AM
prolly can get just the brackets from front range offroad. but your still going to need axle shafts. You do not need axles if you are just doing disc brakes. If you go full floater that you get need new axles plus a bunch of other stuff!!!!!
"Serenity through Sobriety"
[Re: OOP'S]
#671794
11/30/05 01:17 PM
Nope, just doing the rear disc conversion. I can pickup the other parts at NAPA. Might need some small parts from Toyota. Looks like I'll be making a call to Sky manufacturing. Thanks
[Re: Greg_Canada]
#671795
12/01/05 03:56 AM
Toyota Moderator
SKY sells them, much cheaper than the downey brackets, and they also sell everything else you need for a rear-disc convo. Personally I would not purchase anything from Sky Manufacturing, but that is just my opinion. I am running the All-Pro disc kit but if you just want brackets you can get them from TSM Manufacturing .
[Re: DirtyHarry]
#671796
12/01/05 05:52 AM
you can get the brake lines and calipers from "napa" but you will have to machine the rotors to fit over the axle
91 pickup 5.29's US GEAR.35x 12.50 trxus m/t.5 speed swap- SOLD! 96 4Runna limited-toytec/OME lift,diff drop Nitto 285/75/16 Elocked=butter 07 FJ cruiser 3" DR coilovers 285/75/16 nitto TG. allpro sliders
[Re: DirtyHarry]
#671797
12/01/05 05:55 AM
[Re: 87Toy4x4]
#671798
12/01/05 04:13 PM
Toyota Section Staffer
OK, I will speak for just myself. THIS IS MY OPINION ONLY, BASED ON OBSERVATION. YMMV.
Almost everything Sky sells was invented elsewhere with much care, then shamelessly copied (at somewhat lesser quality to undercut price, sometimes it matters, sometimes it does not). I choose not to support such a thing.
Price is not everything. And this is coming from a major cheapskate.
-Bill '87 4Runner w/ '96 5VZ-FE, 'Red Chili II' '97 Taco XtraCab 3RZ-FE, 'BlackBean' TLCA # 13257, Rising Sun 4x4 Club Land Use Coordinator "He who stops being better stops being good." -Oliver Cromwell
[Re: Red_Chili]
#671799
12/01/05 06:30 PM
Toyota Moderator
Exactly. I have friends in this industry who are very talented and work hard designing new parts because they LOVE what they do. Then someone comes along and copies the design and makes it out of cheaper material and undercuts the price. Budbuilt's website puts it best: "We are striving to produce parts that fill a need in the Toyota community without just copying others products. Life is too short to make the same parts that others do! There is lots more that needs to be produced, including some small, helpful parts that make things work better. "
