Re: '98 Isuzu Rodeo Suspension Lift... Which one? #672471 12/03/05 12:23 AM
Bansil Offline
I asked a local 4x4 shop about lifts and they told me that whenever I raise my truck I need to compensate with wider tires to keep stability... is this what backspacing is all about? helping maintain stability?
It is always better to go wider......so go with a 265x75x16
it will be taller about32" and wider than stock plus it will fit on factory 16" rims.
Oh' and when you crank the torsion bars up to match the rear lift the rodeo will be alot more stable on the roads....almost like a very fat corvette <img src="/forums/images/graemlins/ignore.gif" alt="" />
-This is my DD truck so do you think I should stick to All Terrain tires intead of Mud tires.? (I drive about 120 miles highway daily, sometimes more). Oh, and I also read I can go up to 7 inches with suspension lift and body lift... will that afect my 'comuting experience'?
Don't go bigger than 32's if there are hills there <img src="/forums/images/graemlins/smile.gif" alt="" /> and yes AT's would be better.....look at the Revo's several folks have them and like them.
I think I may buy piece by piece... first the OME coils, then the Racho 9000's... can I just change the coils and keep my current shocks? (I bought them like 2 months ago... before I started looking at off roading) or should I go for the whole package?
yes and no <img src="/forums/images/graemlins/confused.gif" alt="" /> you can put the coils in and lift the front..but when you hit a big bump or curb <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> the back will max out the shocks and your kidneys will almost make your seat wet <img src="/forums/images/graemlins/lol.gif" alt="" /> but I have over 30k on mine with stock shocks which are due to be changed out with the longer ones in the back of the truck(for almost a year <img src="/forums/images/graemlins/shiner.gif" alt="" />now)
-Like I said my truck is 2WD, what kind of offroading would I be able to do after the suspension lift... I think that mud will be a no no, but how about going over some rocks or ditches?
lock it up in the back and you'll embarras alot of "4wd's" that are open/open......it's really a good feeling <img src="/forums/images/graemlins/kewl.gif" alt="" />
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Re: '98 Isuzu Rodeo Suspension Lift... Which one? [Re: TrooperJ] #672472 12/03/05 03:19 AM
I'm familiar with LSD and that's something I had in consideration, is there a way to find out if my truck has one already?
Oh, and my rims are stock 15s, I hope they make 265x75x15... or I can buy some rockcrawlers!! (49.99 per rim) I didn't think they cost that little...
Now to save some money!!
Re: '98 Isuzu Rodeo Suspension Lift... Which one? #672473 12/03/05 07:01 AM
NATO308 Offline
Just get some OME 912 or 919 rear springs from http://www.rocky-road.com/ and crank the torsion bars. Rocky Road sells Old Man Emu springs for all Isuzu's, you will have to order those listed for the Trooper to get the OME 912's ro 919's. Rocky Road is the cheapest I have found for OME springs, right at $155 with shipping. I have been happy with Calmini Shocks, although they no longer make the ones I am using. Gabriel Ultra and Pro Guard are a nice inexpensive shock that works great on lifted Isuzu's, Ultra in the rear and Pro Guard in the front on my 2000 and 2001 Rodeos. You can lift a late model Rodeo or Amigo with all new shocks and new rear springs for around $250.
LSD was usually installed on the 4X4 with disk brakes. You can check your rear axle to see if it has 2 ID tags attached to the back plate to see if it limited slip.
'94, and '00 Amigos and '00, 01 Rodeos. Rodeo springs and aftermarket 'hard top on 94. Aisin hubs OME 919's on the 2000 Amigo. 2000 and 2001 Rodeos have OME 912's and Aisin. Smoother ride with the OME 919's???
Re: '98 Isuzu Rodeo Suspension Lift... Which one? [Re: NATO308] #672474 12/03/05 08:53 PM
COTrooper Offline
It seems to me that this can also be determined by looking at the plate on the firewall (driver's side) in the engine bay, right? You should see a "G80" code if it has the LSD. Mine has it, but I didn't notice that code on the plate until after I bought it. Just lucked out, I guess... <img src="/forums/images/graemlins/kewl.gif" alt="" />
'98 Rodeo, Ranchos, OME 912s, General Grabber AT2 265/70/16s on steelies, Superwinch hubs, G80 code, Pioneer HU... two car seats and cracker crumbs.
Illegitimus non carborundum.
Educatio est omnium efficacissima forma rebellionis.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6076 MB (Peak: 0.6839 MB) Data Comp: Off Server Time: 2026-06-17 10:36:34 UTC
