no hot air #672903 12/02/05 04:09 AM
89toyOn35s Offline OP
hey a guy at work has a 99 expidition 4x4 4.6 triton v8 and his wife is saying there is no heat comeing from the vents in the truck we checked the a/f and changed the thurmostat
still doesn't work what else could it be thanx
Re: no hot air [Re: 89toyOn35s] #672904 12/02/05 03:13 PM
W
wyleone Offline
Busted blend door or the blend door motor. That is if the cooling system is good to go. When it has run for a while, touch the heater hoses and see if they are hot, both should be. If only one is hot the the heater core is stopped up inside. I do not envy any man that has to do a heater core in a Expedition. The first one I swapped out took 12hours. After 5-6 more I can do them in 3-4. This is using power tools too. My vote in the blend door motor is not working, either circuit wise or the motor is just bad.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5859 MB (Peak: 0.6334 MB) Data Comp: Off Server Time: 2026-06-09 04:58:46 UTC
