Rear spring bushing suggestions? #673649 12/04/05 08:57 PM
Staceman Offline OP
Customizing my rear '85 springs for the front. The old front bushing on the rear springs had the rusted sleeve-bolt problem. Had no choice but to bust apart and clean out all the existing factory bushing. Anyone know of a Daystar or Energy Susp. replacement bushing kit that will allow me to use the existing front frame pin to mount these on the front??? Thanks all.
Re: Rear spring bushing suggestions? [Re: Staceman] #673650 12/04/05 09:55 PM
4Crawler Offline
I carry a replacement poly bushing that comes with a sleeve to allow a 14mm bolt (like stock) or remove the sleeve for an 18mm bolt (like the front pin) to be used, $20 for the pair + shipping:
http://www.4crawler.com/4x4/ForSale/Shackles.shtml#OrderingInfo
Re: Rear spring bushing suggestions? [Re: 4Crawler] #673651 12/04/05 11:07 PM
Staceman Offline OP
By Pair, do you mean the 2 pieces for one spring, or the set for 2 (pair of) springs? Thanks Roger.
Re: Rear spring bushing suggestions? [Re: Staceman] #673652 12/05/05 12:10 AM
4Crawler Offline
A pair of bushings for one pair of springs, i.e. 2 pair of 2 bushing halves and sleeves. So 4 bushing halves and 2 sleeves total.
Re: Rear spring bushing suggestions? [Re: 4Crawler] #673653 12/05/05 02:56 AM
Staceman Offline OP
You the man Roger! You've got PM <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6067 MB (Peak: 0.6718 MB) Data Comp: Off Server Time: 2026-11-14 14:54:10 UTC
