High RPM missing #674012 12/06/05 01:41 AM
Roll_me_over Offline OP
O-k...looking for some suggestions here. On the way home today I was cruising on the freeway when the ole monty started to miss. I slowed down and it runs fine untill about 2500-3000 rpm when it starts to miss. It only does it in 4th and 5th gear. I pulled the plugs to discover that #1 and #4 cylinder plugs had a "crust" on them. The other plugs looked fine. I checked the wires and all the connections on the coil. Everything checked out fine... What could cause this? <img src="/forums/images/graemlins/confused.gif" alt="" />
02 Ford F-250 4X4 PSD...zero body damage
67 Weimann 18' Jet boat...zero body damage except for the trailer drags on the ground from time to time
Re: High RPM missing [Re: Roll_me_over] #674013 12/06/05 07:30 AM
O
ojo1 Offline
when you say crust - describe it - what color?
Show me the muddy. . . .
Re: High RPM missing [Re: Roll_me_over] #674014 12/06/05 05:00 PM
LRJ4x4 Offline
what did the 2 and 3 plug look like?
Re: High RPM missing [Re: LRJ4x4] #674015 12/06/05 05:11 PM
lordtrunks Offline
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: High RPM missing [Re: LRJ4x4] #674016 12/06/05 09:57 PM
It was like a brownish color. And I'm not saying like a fine crust. It was pretty thick. Like between 1/16 and 1/8 of an inch for lack of a better way to describe it...
they had the normal light brownish look on the electrode insulator...
Re: High RPM missing [Re: Roll_me_over] #674017 12/06/05 11:35 PM
LRJ4x4 Offline
I assume your using all the same type and heat range of plugs <img src="/forums/images/graemlins/smile.gif" alt="" /> Anyways just change them out with some factory plugs NKG's and see what happens. Don't waste your $$$ on any of those fancy aftermarket ones.
The two inside plugs burn different than the outside due to the design of the intake manifold. How many miles on these plugs?
Re: High RPM missing [Re: LRJ4x4] #674018 12/07/05 12:52 AM
And what had the gap opened up to? My money is on .050.
Are the deposits dry crusty, or oily crusty? You might suspect a water leak at the base of the carb, fender side.
Re: High RPM missing [Re: fasteddy] #674019 12/07/05 07:00 AM
plugs have maybe 10-15k on them and the gap was still at the correct setting. The crust was dry... As far as the missing, i changed the coil and the problem is solved...but the plugs have me baffled....
Re: High RPM missing [Re: Roll_me_over] #674020 12/08/05 05:12 PM
Check all the head bolts for tightness. Pressure test the radiator and listen at the carb for the leak.
Re: High RPM missing [Re: fasteddy] #674021 12/09/05 06:19 AM
so a coolant leak may cause the plugs to build up deposits...hmmm...that could be it considering that small hose from the carb to the intake broke spewing coolant everywhere the other day...
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6320 MB (Peak: 0.7236 MB) Data Comp: Off Server Time: 2026-05-31 15:29:26 UTC
