Spindle Bearings
#674063
12/06/05 03:09 AM
Got a price for Spindle bearings today from the dealer - $341 (CDN) for the pair!!!! WHAT!!! Dealer says toyota changed the design from a Brass bushing to a Roller bearing and thrust washer. So either where do I find them cheaper? A LOT CHEAPER??? oR can I find the old style bushing? My truck originally came with ADD hubs, so that expains why their worn out, but I've got Manual hubs now so I can handle the reduced life of the bushing if they're available. I found this article http://www.yotatech.com/~corey/tech/jimrockford_spindle/jimrockford.htm on replacing toyota spindle bearings. It looks like the spindle and the steering knuckle are one piece (I didn't know that), does the steering knuckle have to be removed from the truck, or can this be done on the truck. Any more advise? Tyler
'92 Toyota, 4x4, 22RE, winch, locker, 4.88's, 33's, 2" Body Lift.
Re: Spindle Bearings
[Re: TyYota]
#674064
12/06/05 03:28 AM
Well considering it looks like you have to use a press for the install. I would say yes they have to come off!!!! Not that hard to remove them!!!!!!
"Serenity through Sobriety"
[Re: OOP'S]
#674065
12/06/05 04:05 AM
there are still the regular brass bushings but they redesigned the for cold climate trucks to use needle bearings so they dont moan when its cold. i priced them out and the inner was 34 and outer was 20
91 pickup 5.29's US GEAR.35x 12.50 trxus m/t.5 speed swap- SOLD! 96 4Runna limited-toytec/OME lift,diff drop Nitto 285/75/16 Elocked=butter 07 FJ cruiser 3" DR coilovers 285/75/16 nitto TG. allpro sliders
[Re: willzrunna96]
#674066
12/06/05 03:59 PM
Toyota Section Staffer
With locking hubs the old style brass bushings will work just dandy. Use a press, not a hammer - they distort easily.
-Bill '87 4Runner w/ '96 5VZ-FE, 'Red Chili II' '97 Taco XtraCab 3RZ-FE, 'BlackBean' TLCA # 13257, Rising Sun 4x4 Club Land Use Coordinator "He who stops being better stops being good." -Oliver Cromwell
[Re: Red_Chili]
#674067
12/06/05 05:40 PM
Where can I find bushings? Dealer says the bearings have superseded the old bushings.
[Re: willzrunna96]
#674068
12/07/05 04:43 AM
there are still the regular brass bushings but they redesigned the for cold climate trucks to use needle bearings so they dont moan when its cold. i priced them out and the inner was 34 and outer was 20 Hey all! Not trying to redirect the subject, but I notice that groan with the temp. gets down into the teens. Only lasts a very short distance. Serious or just annoying? Thanks y'all...sorry for the off topic, but first time I'd heard anyone else mention this.
#674069
12/07/05 04:26 PM
Annoying. The spindle is oscillating due to the grease being extremely stiff/missing. I suppose you could be galling the bronze but I doubt it.
Personally, I would defeat the ADD and use locking hubs to fix the problem.
[Re: TyYota]
#674070
12/07/05 04:27 PM
Where can I find bushings? Dealer says the bearings have superseded the old bushings. Sorry, I've never gone down that road (see reply above). You could check the boneyard. What leads you to believe you need to replace them (I assume you've measured clearances against the FSM specs)?
