Re: Transmission Problems [Re: tech30528] #674596 12/10/05 06:18 AM
dcg9381 Offline
Marlin has the parts you need.
22REturbo.net
1988 4Runner
Re: Transmission Problems [Re: Terrys_85_Toy] #674597 12/10/05 07:57 AM
am i seeing things, or is one of those teeth FOLDED OVER ???
how did it do that?
it just fell apart?
nice gear...
dun think i'd be buying anything else from them tho
<img src="/forums/images/graemlins/frown.gif" alt="" />
no warantee ?
Re: Transmission Problems #674598 12/10/05 12:01 PM
Brian894X4 Offline
If they rebuilt the tranny, most likely it was just bearings and snycros. Usually the original gears are left in unless there is specific damage. Plus new gears are pretty expensive, so this probably isn't the tranny rebuilder's fault, unless a bearing went out first which cause the gear to go out.
The biggest problem with Toyota transmission and diffs is not that they can't last 200 or 300K miles. It's that owners, usually the ones that have the truck before us, almost never change the fluid as often as they should. They'll change the engine oil every 3000 miles religiously, but then drive on the same tranny fluid for 70K miles.
Re: Transmission Problems [Re: Brian894X4] #674599 12/12/05 07:29 PM
Terrys_85_Toy Offline OP
Yes, the tranny had new bearings and syncros put in, not new gears, so I'm not blaming anyone.
Three teeth sheared off the gear. My wife was driving the truck at the time. She was cruising down the highway at about 65 MPH in 5th gear when it broke. Fluid level was full. Must have just been fatigue from 20 years of driving. The 3 teeth were sitting in the bottom of the case by the drain plug. Didn't see any other damage.
I swapped out the tranny from my '84 4Runner that I just picked up to make into a family rig. So that project is on hold till I get the tranny fixed or get a replacement.
1985 Toyota Pickup
5.29's
Rear Spool
Dual Cases
35" BFG MTs
Re: Transmission Problems [Re: Terrys_85_Toy] #674600 12/13/05 08:31 PM
Red_Chili Offline
Toyota Section Staffer
Looks like somebody had a habit of dropping the clutch in first maybe??? EEEK.
-Bill
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6103 MB (Peak: 0.6714 MB) Data Comp: Off Server Time: 2026-07-14 12:34:18 UTC
