Page 2 of 5 1 2 3 4 5
Re: Another SAS started(with pics) [Re: spacecab90] #674841 02/09/06 05:33 AM
paulevans76 Offline
have you thought about losing the body lift?
88 Troop - Posing yard art
Re: Another SAS started(with pics) [Re: paulevans76] #674842 02/09/06 07:16 AM
Sammy Offline
With the way the frame extension is mounted, I'm guessing that some body lift will be necessary to keep those forward facing square tubes from hitting anything. That is a lot of lift, however. Looks dangerous without a full width axle. Before you go and remove a bunch more leafs, have you considered trying spring under?
Sammy
95.5 Rodeo, automatic, 3.2 SOHC, D44 front and rear, 4.88's, 33" muds
Re: Another SAS started(with pics) [Re: Sammy] #674843 02/10/06 12:53 AM
CPOM Offline
I would get rid of the body lift and cut whatever is in the way. You can fabricate a new front radiator support as your's is probably rusted out anyway.
CHRIS
98 Amigo, 92 Pup
Re: Another SAS started(with pics) [Re: CPOM] #674844 02/18/06 01:33 AM
spacecab90 Offline OP
Today i got rid of the body lift... I had to do some cutting and beating on the radiator support to make room for the new "frame",but everthing turned out well i think.
Took a few leaves out of the spring packs....
and made a really obnoxious differential cover, from a new dana cover, and spent a couple hours beating quarter inch by 1.5 inch strap with a sledge hammer, to help protect the ring gear.
I think it turned out well, and it displays some pride for my team, even though they did really horrible this past year hahaha...
1990 Isuzu Spacecab, SAS 95% done
'06 Nissan Sentra SE-R Spec V
Re: Another SAS started(with pics) [Re: spacecab90] #674845 02/18/06 03:42 AM
matthew Offline
:clap: :clap: :clap:
much better.....now it's starting to look like something. <img src="/forums/images/graemlins/wink.gif" alt="" />
your diff is almost done............just waiting on an inner pinion bearing <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
'93 RS 3.2L - DD/trail build
'97 7.3L Powerstroke - tow rig
'71 FJ40 - V-8, nv4500, atlas, D60, 14B - current build
Owner: http://www.INDEPENDENT4x.com
m-f 9am-6pm EST. 804-550-0480
Re: Another SAS started(with pics) [Re: spacecab90] #674846 02/18/06 03:44 AM
onebadtrooper Offline
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> Looks sweet!!!!! If I didnt need a new engine soon, I'd be next in line for doing a SAS <img src="/forums/images/graemlins/smile.gif" alt="" /> Can you get some side shots? I want to see what those 37's look like <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Another SAS started(with pics) [Re: onebadtrooper] #674847 02/18/06 04:53 AM
CPOM Offline
Looks good with the reciever and all the gussets in the front. And 10x better with no body lift. Have you tried flexing it up yet to see where it rubs?
CHRIS
98 Amigo, 92 Pup
Re: Another SAS started(with pics) [Re: spacecab90] #674848 02/18/06 06:13 AM
wb86 Offline
<img src="/forums/images/graemlins/kewl.gif" alt="" /> Lookin good!!! Nice to see pick-up recieving a SAS
Craig
1986 Isuzu Trooper 2dr LWB
1999 Saturn SL
Re: Another SAS started(with pics) [Re: wb86] #674849 02/18/06 09:29 AM
Sammy Offline
Damn, there's Green Bay fans everywhere -- even under a solid axle Rodeo in Virginia. Just as dedicated as Raider fans, but with midwest innocence. Yes, I grew up in Wisconsin.
Good job on all the progress. Throw some more photos up when you get a chance.
Sammy
Re: Another SAS started(with pics) [Re: Sammy] #674850 02/19/06 12:00 AM
Well here are a few more pics....
Measuring for shock length, and tire clearance..
I thought there would be a lot more rubbing on the fender. My only concern, is the tires are rubbing on the springs.. Nothing a longer steering stop can't take care of.
Side shot, stuffed up in there about as much as it will go. There is roughly 5 inches between the frame rail and the top of the spring plate.
I will have to cut just a little bit of sheet metal, but not nearly as much as i was suspecting..
TO DO:
bump stops
Brakes lines
Drag Link
Front Diff Install
shock mounts
SPring over rear
making some sort of sway bar out of the old torsion bar
and of course reengineering everything after its done to work properly.
Peace
Joel
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6451 MB (Peak: 0.7499 MB) Data Comp: Off Server Time: 2026-06-17 06:23:47 UTC
