Page 1 of 3 1 2 3
do toyota heaters just suck? #675272 12/09/05 02:17 AM
sdsnowman Offline OP
ive checked my control cable and valve for smooth operation and or clogs, flushed out my entire cooling system, flushed the heater core and water flowed very free and clear, i have a toyota t-stat w/ the 1/4" hole in it.... the fan motor works perfect, new anti-freeze.... still cold!!!
anything i am overlooking?
my last 4runner had the same issues.
87 w/ 22re etc....
Re: do toyota heaters just suck? [Re: sdsnowman] #675273 12/09/05 02:22 AM
dewmtndew Offline
mine heats up so hot I have to turn it off sometimes.
It used to be cold as ice, really wish I remember what I did to fix it....
erick
85 Pickup
33s, lift, EB cam, header, exhaust...
Re: do toyota heaters just suck? [Re: sdsnowman] #675274 12/09/05 02:25 AM
SALMONHEAD Offline
I'm always having to turn down the temp on mine, it's like an oven so something must be up with yours.
84 4RUNNER,22R,HEDMAN,WEBER 32/36,Davis Unified Ignition,33" BFG
Re: do toyota heaters just suck? [Re: SALMONHEAD] #675275 12/09/05 02:33 AM
Rauch_Off_Road Offline
Toyotas came with a standard thermostat and you can usually go warmer. My 3.0 came with a 180 degree and I just swapped in a 192 I think and it helped. Place some cardboard in front of the rad and see if that helps some.
(aka suprathepeg, aka Sean)
Re: do toyota heaters just suck? [Re: Rauch_Off_Road] #675276 12/09/05 02:39 AM
kewlynx Offline
Cardboard won't help him out; he's in Kali. He needs to fix his system.
Fire it up to temp, shut off. Lightly touch fins with fingers; cool spots are clogs. It's a place to start at least.
Also make sure your t'stat is installed the right way.
**ubi apis- ibi salus**
Re: do toyota heaters just suck? [Re: kewlynx] #675277 12/09/05 02:41 AM
cooling fins on the radiator- or heater core?
t-stat is installed the right way- radiator is new...3 row
Re: do toyota heaters just suck? [Re: sdsnowman] #675278 12/09/05 02:44 AM
kewlynx Offline
Radiator. Well, last resort before tearing into the heater core is to see if the blower resistor is still okay. Junkyard or dealer for under $20. I think the p/n is in the sticky.
Re: do toyota heaters just suck? [Re: kewlynx] #675279 12/09/05 02:47 AM
could you please explain what the blower resistor is .... and where.... and how to test....
Re: do toyota heaters just suck? [Re: sdsnowman] #675280 12/09/05 02:49 AM
kewlynx Offline
Re: do toyota heaters just suck? [Re: kewlynx] #675281 12/09/05 03:32 AM
DirtyHarry Offline
Toyota Moderator
The Comanche had a terrible heater in it and it gets fairly cold in Reno in the winter. I didn't know what the problem was but my father spliced a hose fitting into the heater hose line and then we disconnected the other heater hose. I was shocked at how much crud came out! The heater worked a lot better after that too and it was about as cheap of a repair as you can get.
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6381 MB (Peak: 0.7603 MB) Data Comp: Off Server Time: 2026-06-21 09:32:22 UTC
