Re: do toyota heaters just suck?
[Re: DirtyHarry]
#675282
12/09/05 03:37 AM
i pulled the glovebox out and checked everything under the dash- physically everything looks fine. all connectors plugged in and... stumped.
[Re: sdsnowman]
#675283
12/09/05 03:45 AM
you could try backflushing your heater core. most people do that and a bunch of crud comes out. just take off both of the hoses connected to it and put a garden hose to one of them.
btw, you wouldnt be able to see if your blower resistor was bad by looking under the dash. you have to unscrew the one screw that connects it and see if any of the coil things are burned up. but if all speeds on your fan work then it should be good.
[Re: 87Toy4x4]
#675284
12/09/05 03:52 AM
i did the backflush thing and the water flowed fast and clear. the fan motor works fine.
i guess i might have to take it to.... a repair facility!!!
[Re: sdsnowman]
#675285
12/09/05 03:55 AM
my heat fry's my eyes out what about that heater control valve
91 pickup 5.29's US GEAR.35x 12.50 trxus m/t.5 speed swap- SOLD! 96 4Runna limited-toytec/OME lift,diff drop Nitto 285/75/16 Elocked=butter 07 FJ cruiser 3" DR coilovers 285/75/16 nitto TG. allpro sliders
[Re: sdsnowman]
#675286
12/09/05 04:01 AM
Follow that troubleshooting tree I posted for ya man!! If you've done all that other stuff, you might be up into the heat controls.
[Re: kewlynx]
#675287
12/09/05 04:23 AM
Make sure the valve on the firewall is working right and is not clogged. Replace the heater hoses they could be clogged. The heater in my 90 works well enough that I do not put my full doors on for winter snow runs!!!!!!:D
"Serenity through Sobriety"
[Re: sdsnowman]
#675288
12/09/05 04:52 AM
i have a toyota t-stat w/ the 1/4" hole in it.... 1/4" hole is way too big. Try about 1/16". Make sure your fan clutch isn't seized as well.
85 Toyota SR5 Xtra Cab P/U
[Re: sdsnowman]
#675289
12/09/05 05:00 AM
Had the same problem in my little 85' flatbed w the 22r. Over the winter a mouse got in the evap housing under the dash and made a nest . Everytime I hit the blower it smelt of rat pi** and about drove me insaner. Ended up purging the freon at a cooling shop so it was reclaimed then took the truck home and pulled the entire fan/ evap/ heater core out and cleaned and disinfected it with every chemical I could find . A mild amonia solution did the best on the odor and purple plus cleaned the dirt out . You wouldn't believe the dirt and dust and dog hair and lint in addition to the frikin rat nest that was impacted almost to a mat that had built up over 20 years and was preventing AIR Flow. After that it worked at least 5 times better .
85' 4x4 e-cab flatbed 22r carb ((SOLD)) 86' 4runner, 22re , "60 buck truck" 95' 4runner, 22re,5sd, last of the good ones 02' Tacoma prerunner, 2.7L, 5spd., 4x4
[Re: Cholltero]
#675290
12/09/05 06:00 AM
Yeah a 1/4" hole is way too big. Where does your temp gauge needle sit at during normal operation?
[Re: OOP'S]
#675291
12/09/05 07:41 AM
Make sure the valve on the firewall is working right and is not clogged. That's where I'd look first. I ended up replacing my '88 valve with one from a newer model truck that mounts a little bit differently. The newer style valve seemed to look much cleaner in design and operation to me. It took some very slight tweaking to get her in place, but it will work and can be done. <img src="/forums/images/graemlins/kewl.gif" alt="" />
'88 X-Cab 4x4 '00 4Runner '91 Talon TSi slacker Mitsu tech
