can I use brake fluid soaked brake shoes?
#675582
12/10/05 12:26 AM
it appears not to affect performance but i would prefer not to change em only to find out differently brand new shoes i see no reason to throw them away unless they are in fact trash now
Re: can I use brake fluid soaked brake shoes?
#675583
12/10/05 12:40 AM
Yes, you can. Running them without cleaning them will glaze the drums, and lead to squeaky brakes. The boiling temperture of DOT 3 fluid is about 230 degrees F, Dot 4 is about 265, so it would take a lot of heat to get the fluid out of them. However, both types are water soluble. So wash them down with water, then gently heat them with a torch. The heat will draw the brake fluid to the surface so it can be washed away. Do this 4-5 times, you should be ok. Then lightly sand them. If you are using DOT 5 fluid, replace the shoes. It has a very high boiling point, and is silicone based, so is not water soluble.
Just in case anyone disputes this info, it came from Motor magazine, an industry publication, in an article titled "silver bullets", a compilation of tips sent in by professional who use these methods.
[Re: tech30528]
#675584
12/10/05 01:32 AM
GENTLY heat em with a torch ??? <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/cyclops.gif" alt="" />
so much for gettin it dun today
sumthin musta come loose in one o my brakes cuz it makes a clank every time i take off and shift in lower gears and it dun appear to be the driveshaft/pinion torques duzn't do it in reverse
#675585
12/10/05 01:41 AM
hose em with brake cleaner if it's not too much in there.
i thought dot 3 boils at something like 450*? 230 isn't much higher than water, which is the big reason you never want water in your brakes -- it'll boil and they won't work.
'79 sport 4x4 longbed <img src="/forums/images/graemlins/smile.gif" alt="" /> 20/22R hybrid with EB's OS valves, 268c cam, offy intake, weber 32/36, thorley header, 5 speed swap, 34" LTBs, downey 3" springs, marlin hysteer, 4.88s and locked
'91 4x4 shortbed 22R-E, W56, the dd!
#675586
12/10/05 02:23 AM
A bit of brake fluid triva
Lets look at what the DOT ratings mean. The table below shows the MINIMUM wet and dry boiling points for DOT 2, 3, 4, and 5 brake fluid in degrees fahrenheit.
DOT 2-Dry Boiling point 374
DOT 3-Dry Boiling point 401 Wet boiling point 284 DOT 4-Dry Boiling point 446 Wet boiling point 311
DOT 5-Dry Boiling point 500 Wet boiling point 356
The DOT 2 spec is for drum brakes and is obsolete. If you have any DOT 2 in your garage, throw it away! DOT 5 is for silicone brake fluid. Silicone brake fluid (DOT 5) should be avoided because it is not compatible with regular brake fluid, it is hard to pour without introducing bubbles and thus results in soft pedal feel, and moisture still gets into your system and will pool in low areas like your calipers and encourage rapid corrosion. STAY AWAY!
That leaves DOT 3 and DOT 4 fluids. These fluids are compatible with each other and may be interchanged or mixed with no ill effects.
"Serenity through Sobriety"
[Re: OOP'S]
#675587
12/10/05 04:46 AM
Lets look at what the DOT ratings mean. Good stuff. I knew that first posted info was abit off. Anyways, just get some new shoes. Cheap, will last forever, easy to install and there's no dicking around with torches.
'88 X-Cab 4x4 '00 4Runner '91 Talon TSi slacker Mitsu tech
#675588
12/10/05 04:51 AM
hosed em good with brakeleen no way of telling if they still got brake fluid in em tho linings are black looks like they're made of uhm, asphalt ??? <img src="/forums/images/graemlins/frown.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/rodent.gif" alt="" />
hope there are no deadly fumes involved in torchin em inhaling that brakeleen is bad enuf
#675589
12/10/05 05:55 AM
Is this really all worth not having to pay $15 for a new set of shoes? Torching your brake pads? It's not to me.
[Re: Adam F]
#675590
12/10/05 09:23 AM
Is this really all worth not having to pay $15 for a new set of shoes? Torching your brake pads? It's not to me. no kidding. I don't understand how some people will spend lots of time doing some insane fix that will cost more in time, when you conld just go buy a new part for much cheaper....REMEMBER: time=money and I'm much too lazy to do something stupid like that.
-1986 TOYOTA 22R ZUK coil rear Torqued T-Bars Marlin HD clutch
AZTTORA #492 TLCA member
"I hear there's rumors on the Internets that we're going to have a draft." --George W. Bush
[Re: 4WD22R]
#675591
12/10/05 03:29 PM
i recycle my toxic chemicals too
glad u are so rich
b4 autozone there wuz a store down the street... but the sane days are gone forever traffic, rush hour, wait in line behind dorkasaurus trying to find bling for his scooter
i'm gonna try it just to see wut happens unless i'm outta propane
i wanna see brake fluid bleed or ooze or wutever it duz
