Info on ECM needed. #675760 12/10/05 07:52 PM
E
elnido Offline OP
Hey all, after a year of PO773 I had shift solenoid E replaced. The Toyota tech said everything is functioning correctly, however my ECM is "going" so its having mis-communication with the solenoids, which in time will cause premature failure. The truck still throws PO773 even though that part is replaced.
My question is about the ECM's function. Also, I have the part #(not with me at the moment), and was looking for suggestions for finding a used one. (new $1080.00).
Thanks for any input.
95 t100 5vzfe A/T 4x4
Re: Info on ECM needed. [Re: elnido] #675761 12/11/05 12:36 AM
garym Offline
They come up on ebay once in a while for between $75-$150. Keep looking and make sure it is for the A/T.
Car-parts has a bunch listed for around $300 and seems 2/95 mfg date on is different from 1/95 and before:
parts
Just noticed a 95 wiring manual you might be interested in on ebay now:
95 elect manual
1997 T-100 4X4 Xcab,Warn Hubs
02 Camry LE
2008 Yaris
Has anyone every had an ECM refurbished (R&R'ed)? [Re: garym] #675762 12/12/05 09:36 PM
E
elnido Offline OP
(thanks gary)
I'm torn between gambling 150 for a used replacement or $300 on mine being refurbished.
Re: Has anyone every had an ECM refurbished (R&R'ed)? [Re: elnido] #675763 12/14/05 02:27 AM
4
4xGeek Offline
It's not really an item that goes bad very often... Probably fine with a used one. Fwiw, I'm using a used one I got from Surlynkid (after frying mine trying to reprogram it myself... Oops <img src="/forums/images/graemlins/barf.gif" alt="" />)
4xGeek (Chris)
'97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc...
No longer stuck in SoCal!! smile
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6008 MB (Peak: 0.6565 MB) Data Comp: Off Server Time: 2026-06-17 19:37:29 UTC
