Ranger #676047 12/12/05 02:13 AM
I have a 93 ranger 2wd that I am wanting to convert to 4wd.Could someone tell me what parts I need to do this and an approximate cost of the project?Thanks
Re: Ranger #676048 12/16/05 04:34 PM
SMITHTONU02 Offline
You didnt say what kind of motor you have (3.0, 4.0, 4cyl.) But the best thing to do is probably find a 4x4 ranger donor truck with a good drivetrain and swap out the whole deal. It will probably save you in the long run. Make sure u get the same body style(ex. cab or reg.) because it will limit the shortening of drive shafts(because of the added length of the transfer case). You may be able to find some driveshafts to work with minimal machining. Your rear axle will probably work, but u yare definitly going to have to get the new front axle. Like i said it will probably be better to just swap out the whole drivetrain for simplicity. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[*]1997 NISSAN HB EX CAB. 4X4 , 4CYL, 5SPD, 87K MILES, WARN PREM HUBS, MOOG STEERING, 3IN A/C ARM LIFT, 3IN BODY, 32X11.50 MUD TRACS
Re: Ranger #676049 12/16/05 05:39 PM
W
wyleone Offline
That would require an complete front end swap including the the trailing arm brackets. Oil pan on motor, trans and transfer case. I agree, Better find a rolled Ranger and swap over the frame and all. Unless you are an engineer, then cut and paste to your liking.
PHP: 7.4.33 Page Time: 0.012s Queries: 14 (0.010s) Memory: 0.5889 MB (Peak: 0.6423 MB) Data Comp: Off Server Time: 2026-07-14 23:23:02 UTC
