cam seal #676224 12/12/05 06:31 AM
Digital_Aardvark Offline OP
Been losing about a quart of oil a week for the last two weeks <img src="/forums/images/graemlins/shiner.gif" alt="" /> At first I thought it was a valve cover gasket, but I took the valve cover off and it looks good. I had the plastic cover off the timing belt and the belt seemed to have a little oil on it. It also appears as if the oil is coming from the very front of the engine on the passenger side. Is it likely the seal? I'm going to order a new seal and timing belt tomorrow if it is. I need to get this done before I leave school for break while I still have access to the student garage.
1989 3.0 5 spd extended cab with more rust than should be legally aloud, soon to have a D44 front and D60 rear
Re: cam seal [Re: Digital_Aardvark] #676225 12/12/05 07:16 AM
E
Eck Offline
I changed all min out too with the TB. Don't forget the crank seal. I used the old TB to open the cam pulley bolts. Makes life much easier.
92 Xcab V6 4x4 SR5 5sp., Detroit locker rear, lim. slip front, Warn hubs, H4's, electr. fan, eng. oil cooler, 1 lift, open cat.
Re: cam seal [Re: Digital_Aardvark] #676226 12/12/05 07:23 AM
OOP'S Offline
Do your self a favor while you have it open and get a new water pump!!!
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: cam seal [Re: OOP'S] #676227 12/12/05 07:31 AM
thanks for the replies
On the water pump, should I go with new or reman? The price is about about double for a new versus a reman at Napa. Also is it really necessary with only 109k on the clock?
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6018 MB (Peak: 0.6582 MB) Data Comp: Off Server Time: 2026-06-23 18:42:27 UTC
