T100 Alcans on Ebay #677077 12/15/05 01:04 AM
Honger Offline OP
Brand New Alcans for T100
Regular cab 4x4 application.
These are for 3.5 inches of lift. Would this work for an Xtracab as well?
1998 Toyota T100 SR5 ExtraCab 4WD
Re: T100 Alcans on Ebay [Re: Honger] #677078 12/15/05 02:55 AM
4
4xGeek Offline
'Should' be the same... Anyone know for sure?
4xGeek (Chris)
'97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc...
No longer stuck in SoCal!! smile
Re: T100 Alcans on Ebay [Re: Honger] #677079 12/15/05 03:03 AM
H2O_MAN Offline
Should be the same and about $100 below retail.
Call them ~
Re: T100 Alcans on Ebay [Re: Honger] #677080 12/15/05 03:34 AM
Fishen'man Offline
Regular cab 4x4 is a 8' bed right? Does that make a difference?
Re: T100 Alcans on Ebay [Re: Honger] #677081 12/15/05 03:43 AM
Squeezer99 Offline
will they fit up to a regular cab 4cyl 2wd?
Re: T100 Alcans on Ebay [Re: Squeezer99] #677082 12/15/05 03:14 PM
Honger Offline OP
Actually, the auction doesn't mention if they are 4x4 or not. Hmmm... someone needs to call them. Its more lift than I want in any case.
Joel
Re: T100 Alcans on Ebay [Re: Honger] #677083 12/15/05 04:37 PM
adam Offline
Standard/extended cab is part of how they factor weight distribution in building them. IIRC the standard cab would be lighter weight on the rear springs by default, so on an extended cab you might not net 3.5".
~Adam
Re: T100 Alcans on Ebay [Re: Honger] #677084 12/16/05 07:09 PM
Kookadala Offline
I called Alcan and the springs will work for 2 wheel or 4 wheel drive vehicles. However, there is a difference in the bushings between the regular cab and extended cab so the springs on ebay will only work on the regular cab.
Bummer, as I would have bought them otherwise.
96 T100 4x4 - 35's, 4" SL, 2" BL, 4.88s, ARBs, custom bumper & E9000 winch, etc.
99 F-350 4x4 superduty supercab turbodiesel longbed
Re: T100 Alcans on Ebay [Re: Kookadala] #677085 12/16/05 07:15 PM
Jake97T Offline
me too, i really dont like my crooked overload springs, 2" blocks and too stiff ADL.
Re: T100 Alcans on Ebay [Re: Kookadala] #677086 12/16/05 08:32 PM
4
4xGeek Offline
I wonder if it's just a matter of replacing the bushings...?
4xGeek (Chris)
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.010s) Memory: 0.6357 MB (Peak: 0.7389 MB) Data Comp: Off Server Time: 2026-10-25 06:26:17 UTC
