air pressure and mpg #677198 12/15/05 08:36 AM
taro Offline OP
I went a little long on my last tire rotation and noticed that the middle of my front tires were almost bald while the edges were not as worn. The rears looked fine. When I rotated them, I lowered the fronts to 28 pounds hoping to even out the wear while keeping the rears at 35. I noticed tonight that my mpg dropped from the 14s to the 12s. Could the drastic drop be soley to the air pressure drop in the front tires or might there be something else going on? Thanks, Taro
Re: air pressure and mpg [Re: taro] #677199 12/15/05 01:25 PM
litnin Offline
Yep, it sure could.
Wearing in the middle indicates you have way too much
air pressure in the tires.
Relieving some of that air pressure to put more contact patch
on the ground, increases rolling resistance which will reduce
fuel mileage.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake
1989 Trooper 2.6 auto
1989 I-Mark RS DOHC 1.6
1991 Stylus XS DOHC 1.8
Re: air pressure and mpg [Re: litnin] #677200 12/16/05 05:53 AM
taro Offline OP
Thanks for the reply. Gas is starting to go up again. I've been riding my motorcycle most days. If I go ahead and get some heated gloves, I think I'll be alright even down into the 20s provided there's no precipitation.
PHP: 7.4.33 Page Time: 0.023s Queries: 15 (0.020s) Memory: 0.5898 MB (Peak: 0.6430 MB) Data Comp: Off Server Time: 2026-07-15 02:38:39 UTC
