Cutting out radiator support YES or NO (V6 3.0 894runner) #677745 12/16/05 10:55 PM
chuckelbarry Offline OP
OK my new long-block(3vz)is sitting in my carport. i am going to install it this weekend. last time i dropped the motor in it was a pain to get in. even after i took all the belts and headers off. this time i am thinking i will fully assemble the motor on the stand and try to get it in with the radiator support out of the way it looks like it might work?
PS before i cut the support out. I plan on bolting some L channel steal with two bolts on either side of where i would cut the sheet metal. just so it lines back up then take off the L channel cut the sheet metal support out of the way.
Re: Cutting out radiator support YES or NO (V6 3.0 894runner) [Re: chuckelbarry] #677746 12/17/05 04:35 AM
please help? i cant be the only one that thought it would help to cut that dam thing out of the way?
Re: Cutting out radiator support YES or NO (V6 3.0 894runner) [Re: chuckelbarry] #677747 12/17/05 05:14 AM
bkg Offline
Not sure what the issue is. There's plenty of room to get the v6 in w/ the support intact. Done it many times - even once w/ a 4.3 and attached tranny/tcase.
Brian K. Gallus
Re: Cutting out radiator support YES or NO (V6 3.0 894runner) [Re: chuckelbarry] #677748 12/17/05 06:34 AM
1
1FastSS Offline
What are you using to put the motor back in? Should be plenty of room without cutting up the truck.
Engine hoist......just tilt the engine back to get it in.
- Daily Driver - 2004 Corolla
- Off Road - 1992 Pickup SR5 3.0L 4x4
- Fun - 2001 Camaro SS (320 RWHP/330 RWTQ)
http://community.webshots.com/user/1fastss
Re: Cutting out radiator support YES or NO (V6 3.0 894runner) [Re: 1FastSS] #677749 12/17/05 03:14 PM
hdrisc Offline
I would say No. If you cut anything off, youy might run into panel alignment problems later. Are you trying to install the engine with the trans. attached?
If you decide to cut something, get a set of spotweld drill bits. Drill out the spotwelds on the center section (just the top) only and remove that instead of the whole support.
Re: Cutting out radiator support YES or NO (V6 3.0 894runner) [Re: hdrisc] #677750 12/17/05 05:57 PM
i want to fully assmble the motor with the headers (downey). then drop it in.
Re: Cutting out radiator support YES or NO (V6 3.0 894runner) [Re: chuckelbarry] #677751 12/17/05 06:22 PM
bkg Offline
still not an issue. Best thing to do, IMHO, if you are concerned is to get the engine 1/2 in - above the engine compartment, assemble the headers then and drop it down.
I think you're making the project harder by cutting the core support to get it in w/ the headers. If you go that route, you'll have to cut the core from headlight to headlight - there's no benefit.
Brian K. Gallus
Re: Cutting out radiator support YES or NO (V6 3.0 894runner) [Re: bkg] #677752 12/18/05 09:28 AM
4WD22R Offline
Think about how hard it would be to get your headlights lined back up so you can focus the dang things....seems like a major PITA to me and you're makin it for yourself!!! Come on man, work smarter not harder!!! <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: Cutting out radiator support YES or NO (V6 3.0 894runner) [Re: 4WD22R] #677753 12/18/05 08:57 PM
willzrunna96 Offline
i got my 22re with trans and transfer csae in by my self without cuttting nothing. now that i think about it my header was installed to. i think you crazy if your even gonna attempt that. you are taking the hood off right??
Re: Cutting out radiator support YES or NO (V6 3.0 894runner) [Re: chuckelbarry] #677754 12/19/05 11:34 AM
Ganoid Offline
You are probably going to need a small body lift to clear the headers off the passenger side floor board (unless you opt for some heat shielding like others have done). I put my motor back in with very little effort and then bolted the headers up it wasn't that bad really? Honestly I don't think you can get the headers past the frame rails while installed on the motor.
90 Xcab V6
3.0 Rebuilt/Balanced
P/P w/OS valves
Downey Hdrs,Jacobs Ign
5.29's,Tru Trac+Lockright
4"TG SAS+Rear Kit on 35's
(DOA Racing = $1200 lesson <img src="/forums/images/graemlins/angry.gif" alt="" />)
www.performancecylinderheads.com
PHP: 7.4.33 Page Time: 1.428s Queries: 15 (0.003s) Memory: 0.6341 MB (Peak: 0.7377 MB) Data Comp: Off Server Time: 2026-06-01 07:36:31 UTC
