help me please #678064 12/18/05 03:09 AM
toyotaguy55 Offline OP
my 4runner died today. i hit a bump and it shut off and wont restart.Fuel pump ok replaced fuel filter im hoping my computer didnt shi to bed. it seems like its not getting \fuel to the clinders. theres also spark.I cannot figure this out please help :'( its an 86 22re
toyotas look good with body damage
Re: help me please [Re: toyotaguy55] #678065 12/18/05 03:29 AM
willzrunna96 Offline
check the fuses i hit a bump 2 years ago and i kept blowing my EFI fuse. left me stranded on the beach with the tide approaching!! turned out my o2 sensor wiring had fight with the exhaust. guess who won...
Re: help me please [Re: willzrunna96] #678066 12/18/05 03:33 AM
<img src="/forums/images/graemlins/lol.gif" alt="" /> i did check all the fuses i was hopin it was one of them
Re: help me please [Re: toyotaguy55] #678067 12/18/05 04:05 AM
id jump out the B+ and FP terminals in the diagnosis port. i think it puts 12volt directly to the fuel pump if the key is on. see if it goes on. if im wrong someone will chime on in
Re: help me please [Re: toyotaguy55] #678068 12/18/05 04:05 AM
ZUK Offline
check the connectors on your air filter.....
mostly stock
Re: help me please [Re: toyotaguy55] #678069 12/18/05 04:41 AM
3
355Camaro Offline
my truck died when the connector on the Mass Air Flow Vein came loose. Pushed it back in, started up w/ no problems at all
2000 Audi TT 1.8Turbo Quattro
1988 Chevy Camaro - 100% Built + for sale!
Re: help me please [Re: toyotaguy55] #678070 12/18/05 04:57 AM
missouriman Offline
I would unplug and plug back in any and all plugs that I could find.
why do you think it is not getting fuel... squirt some into the inlet. or try a small.. small amount of starting fluid.
check your spark..
Re: help me please [Re: missouriman] #678071 12/18/05 05:04 AM
spark-good
fuel pump good
all conections checked and good
put all new hsoe claps on the intake good
and i think its not gettin fuel but i think that the injectors arnt opening and no fuel can get in.
leave the key on and the feul pressure will build up and squese rough the injectors and it fires for about a second and then nothing again. how can i test that theiory
Re: help me please [Re: toyotaguy55] #678072 12/18/05 06:26 AM
4Crawler Offline
If you jumper the fuel pump test jumper, and turn the ignition on, the fuel pump will run, you should be able to hear it (makes a hissing sound like an air leak). If you don't jumper the fuel pump it will only run when the starter is running if you have some problem with your Air Flow Meter.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6267 MB (Peak: 0.7293 MB) Data Comp: Off Server Time: 2026-07-16 04:59:29 UTC
