Re: Weber conversion on the fly, need help please.
[Re: NathanC]
#678204
12/20/05 08:06 PM
Hmmm, my electric choke always worked just fine. Although it needed ajustment on a regular basis. I ajusted it to a happy medium before I sold it. BTW that Carter elect fuel pump I put on worked real good. Make sure you get a good electric though, only Danwheeler has any good luck w/ cheap pumps. I went through 4 Posi flo pumps (1yr warr) under warranty before I got the bit more expensive Carter. (Lifetime Warranty)
[Re: wyleone]
#678205
12/20/05 09:27 PM
Yeah, there's probably a big difference in winter weather between Northern Illinois and Alabama <img src="/forums/images/graemlins/wink.gif" alt="" />.
I also used a Carter and was pretty happy with it.
'06 Dakota QC 4.7 6sp 4x4 '88 Mighty Max '77 KZ1000 fun old bike
[Re: NathanC]
#678206
12/21/05 04:24 AM
Thanks for the tips, I got it runnin, then went to change the plugs. #3 looked like it had been sitting in oil. Still wet. Sure enough, went around the block and lost a quart of oil so Carb wasnt my only problem.
2001 Jeep Wrangler Sahara/4" Rough Country Lift/BFG 32x11.5x15 I caught this "JEEP thing" of your and now it hurts when I pee.
[Re: juggernaut]
#678207
12/21/05 06:09 AM
[Re: juggernaut]
#678208
12/21/05 07:49 AM
not sure if thats the right picture - that timing cover looks funny. It says SOHC... i'm having a brainfart here but I thought our engines were SOHC. is that a Weber air intake plenum on the right?
1986 Montero 2.6l 31X10.5 BFG MT - Weber carb with custom intake Rear LSD - RCI seats - Oil cooler - Manual hubs Custom bumpers front and rear + rock sliders
[Re: juggernaut]
#678209
12/21/05 02:37 PM
I dunno, I've never heard of that company before. The aftermarket is loaded with crap parts <img src="/forums/images/graemlins/frown.gif" alt="" />.
[Re: juggernaut]
#678210
12/21/05 03:28 PM
I haven't heard of it either. That is just a representitive pic. If you scroll to the bottom he is selling kits for a bunch of motors. The price says stay away, a good set of pistons alone cost that much (actually a bit more). The owner of my Raider before me put junk like that in mine and #3 piston broke less than 30mi later. I rebuilt w/ Weisco and Clevite and it has about 40mi on that build, you can check w/ Mississippi Blue to see how it's running.
[Re: wyleone]
#678211
12/29/05 04:13 PM
Still got yo get it towed home. Looks bad.
I knew that i had some blowby for awhile. (smoke at statup, when AC was on and air cleaner filthy) I dont understand how it went south so fast. Still idles great but looks like a small forest fire behind me.
I can get a rebuilt long block for $1200 locally. Gonna go ahead and setup Weber air cleaner and get the headers installed while I am at it.
[Re: juggernaut]
#678212
12/29/05 05:45 PM
Humor me and do a compression check before you condemn the motor. If the compression is normal on 1,2,and 4 and high on 3 then the rings and valves are good. That will also mean you have a completely gone valve seal on the #3 intake valve. If the compression is low on three then it is piston/ring problems and time for a rebuild.
[Re: wyleone]
#678213
12/29/05 06:19 PM
funny you should ask. I went last weekend and went to start it up to move it. I heard a loud pop and no crank. I found the #3 spark plug still on the wire on the side of bay. I must have not screwed it in and it blew it out, so there is compression on the #3.
