Re: Weber conversion on the fly, need help please.
[Re: juggernaut]
#678214
01/02/06 12:54 AM
Update, Ran cmpression check on her. #1,3,4 would get up to 170 psi, While # 2 wouldnt get past 50 psi. Pulled the cover and none were visibly sticking. Not sure what to do next. I am stuck. I took a bunch of pix but not sure they will show anyhing.
Help Please, any ideas?
2001 Jeep Wrangler Sahara/4" Rough Country Lift/BFG 32x11.5x15 I caught this "JEEP thing" of your and now it hurts when I pee.
[Re: juggernaut]
#678215
01/03/06 10:52 PM
Well, I removed exhaust manifold after finally towing it home. Got most of the interior cover bolts out. Some are in there good. Gonna try to get other side disconnected tonight so I can take a look at the valves.
Am I going in the right direction?
[Re: juggernaut]
#678216
01/03/06 11:17 PM
Could have a blown head gasket. The jet valve heads are also known for cracking. Last time I looked at mine it had six. Still runnin <img src="/forums/images/graemlins/shiner.gif" alt="" />.
'06 Dakota QC 4.7 6sp 4x4 '88 Mighty Max '77 KZ1000 fun old bike
[Re: juggernaut]
#678217
01/04/06 04:50 PM
[Re: juggernaut]
#678218
01/04/06 07:35 PM
thats weird... wonder why it's all gold like that?
1986 Montero 2.6l 31X10.5 BFG MT - Weber carb with custom intake Rear LSD - RCI seats - Oil cooler - Manual hubs Custom bumpers front and rear + rock sliders
[Re: DanWheeler]
#678219
01/04/06 07:37 PM
btw - if you're going to be replacing the head and gasket, here is the procedure: Montero 2.6 Head/Gasket Replacement Procedure
[Re: DanWheeler]
#678220
01/04/06 08:19 PM
Nice write up. I am gonna take to mechanic today. Got some rusted exhaust bolts I cant get off and running out of time. Trying to rebuild after I get home from work is killing me. Dont know how long Dad can lend me his car and will be in Alabama next week.
[Re: juggernaut]
#678221
01/04/06 10:59 PM
Gold from exhaust blowing into oil passages? Funky.
[Re: NathanC]
#678222
01/06/06 02:49 AM
OK, went by mechanic to check out damage. Pistons/Rings look good. No scarring on the walls, headgasket looked good, valves look good - would open and close when turn the crack, no visible cracks - didnt have time to clean up head yet but...
I guess I am gonna go ahead and try to get Clearwater head since it is apart. Hate to put it back together and have same issue.
Stumped the mech and me.
[Re: juggernaut]
#678223
01/06/06 02:46 PM
Clean the area between the valves and jet valves well. That's where they crack.
