Re: Weber conversion on the fly, need help please.
[Re: NathanC]
#678224
01/06/06 06:25 PM
eah, gonna clean it up and look. I got a spare head from my Dad to return as core charge and it had the typical cracks on 2 of em.
2001 Jeep Wrangler Sahara/4" Rough Country Lift/BFG 32x11.5x15 I caught this "JEEP thing" of your and now it hurts when I pee.
[Re: juggernaut]
#678225
01/06/06 06:28 PM
...didnt have time to clean up head yet but... This will be where you problem will likely be.
[Re: wyleone]
#678226
01/07/06 12:19 AM
Just got off the phone, new head on the way. Should be here Thursday.
[Re: juggernaut]
#678227
01/16/06 08:05 PM
Got the new head, not that impressed with packaging or someone dropped it before it went out. Did finally get around to finding the cracks on the old one. http://pg.photos.yahoo.com/ph/kemta...mp;.src=ph&.tok=phOOpQEBeLZ1.N6H
[Re: juggernaut]
#678228
01/27/06 02:27 AM
Well, got head on used all Felpro gaskets. Switched out water pump, timing chain and gears, thermostat, fuel pump, all new belts. Ran for a few minutes like a champ then started to hear a horrific noise. Sounded like a broke rod. Pulled oil pan and cant see any damage but flywheel can move an inch or so without crankshaft moving. Any ideas before I pull tranny to see if it is the problem. Starting to rack up the hours on this thing.
[Re: juggernaut]
#678229
01/30/06 12:26 PM
Yep, flywheel. Fly wheel looked new except that the threads were gone letting it wobble itself loose. All six bolts were that way. Anyway, Flywheel is on the way. Also went ahead and got new clutch, on the way also. My pressure plates was burnt and had leaves in it. That rubber boot from the slave cylinder does serve a purpose. <img src="/forums/images/graemlins/notooth.gif" alt="" />
[Re: juggernaut]
#678230
02/10/06 03:08 AM
Hopefully get the transmision back in this weekend and be back on the road.
Wanna go ahead and replace shocks and do another tuneup while I am throwing money at it.
What size shocks should I get? I have the Tbars cranked and Yota shackles.
It appears everybody loves the KYB, so I guess I will give em a try.
What spark plugs yall prefer?
Any new head breakin tips?
Cant wait to see how the Weber 38 and headers perform. Prolly need a bigger gas tank <img src="/forums/images/graemlins/shiner.gif" alt="" />
[Re: juggernaut]
#678231
02/10/06 04:10 AM
wow thaught i had problems
#678232
02/10/06 04:22 AM
I only paid $700 a year ago for her and I got roughly 35,000 miles out of it so I cant complain except I am tired of driving my Dad's Tracker.
[Re: juggernaut]
#678233
02/18/06 05:20 AM
Cant wait to see how the Weber 38 and headers perform. Prolly need a bigger gas tank <img src="/forums/images/graemlins/shiner.gif" alt="" /> She is home now. Gonna replace the plug, cap, rotor, wires and install the air cleaner tomorrow. She wouldnt run with mech fuel pump so put in electric.
