hub question 89 truck
#678353
12/19/05 03:17 PM
I just got my truck and I have a question about the hubs. One of them is very easy to turn, it just snaps in and out of place. The other take a grunt or two to turn it. Is this normal or is there a problem? I don't mind tearing them open and I should probably repack teh wheel bearings since I have no idea about mainetance the history. (actually, I think it had no maintenance) It has 130,000 miles.
Re: hub question 89 truck
[Re: trythis]
#678354
12/19/05 06:19 PM
Probobly just needs to be repacked. How do the CV boots look?
[Re: trythis]
#678355
12/19/05 08:00 PM
At the top of this page there it a FSM for a 93. All the info you need for cleaning and the procedure for inspecting and the proper way they go to together is there. Use a liberal amount of grease on the hubs otherwise they will not work properly. I use a white lithimun based grease on the hubs. The procedure for packing the wheel bearings is also there.
"Serenity through Sobriety"
[Re: Seattlegti]
#678356
12/20/05 12:35 AM
cv boots look fine, I don't think this truck saw anything worse that a nasty farm road or two, the bottom is clean and scratchless.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5995 MB (Peak: 0.6551 MB) Data Comp: Off Server Time: 2026-06-13 07:58:15 UTCValid HTML 5 and Valid CSS
