Throttle lever #679130 12/21/05 11:42 PM
Cruizin Offline OP
Ok so I'm not a pro wheeler but I have done enough to wish I had an extra leg sometimes. Here's a typical situation. Your going up a steep hill and you have to stop, the clutch is in and the other foot is on the brake. To get going again I usually let the clutch out enough that it starts to grab and then hurry and pull the other foot off the brake and hopefully don't roll back too far. The e brake works as well. This is got to be hard on the drive line and stuff though. I was thinking of rigging a brake lever for a bike to the shifter or something like that that is connected to the throttle. Do any of you guys have other solutions?
Re: Throttle lever [Re: Cruizin] #679131 12/22/05 12:44 AM
F
Fred Blackstone Offline
Rubicon Express has a hand throttle kit that may help in this situation (after you see the kit, you may want to simply buy the parts locally, however). I have a hand throttle with the bicycle adjust on the gearshift lever. It helps in the situation you describe, but is not a cure-all solution, and you still need one right and two left feet! I would estimate that I use the hand throttle maybe 50% of the time; it's fun to set the hand throttle and then slowly cruise up the less difficult mountain trails.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5863 MB (Peak: 0.6343 MB) Data Comp: Off Server Time: 2026-06-22 03:53:17 UTC
