Page 3 of 3 1 2 3
Re: Spun a shaft? [Re: no_hank] #679702 01/08/06 07:20 PM
Softest.
Re: Spun a shaft? #679703 01/08/06 07:46 PM
no_hank Offline OP
Was the install bad? I'd think running all those air lines without snag/rub spots would be a bit of a pain. Do you find that you actually use the adjustment feature or pretty much leave it in one spot? Would you get the 9000's again or go with something else? I've always thought the in-cab adjustment would be neat to have, but I'm also a big fan of keeping things simple.
97 TJ Sahara 4.0, K&N FIPK, 2.5" rancho, 31x10.5 BFG, black rims, tuffy stuff, hi-lift, AA SYE+tom woods CV rear, tera adj. upper rears, centerforce dual-friction, MSD coil/8.5mm, borla cat-back, warn steering skid, slotted rotors+high perf pads.
Re: Spun a shaft? [Re: no_hank] #679704 01/08/06 11:01 PM
Rancho Install
I find that I adjust them depending on my mood and driving style. Most of the time I just leave them soft for on-road driving then firm them up off-road. Sometimes when I get into hilly sections I firm them up to kill some of the body roll.
In the dunes they are very nice. When I'm out hitting bowls or going through whoops at high speed I usually firm them up to control the axles, then when I cruise I soften them up so I don't feel the dunes.
I'd say the reliability of them Is just a little less than an ARB. You can route the air lines in the cab or next to the frame or wherever you want to, but there is a line going to the shock. If you drive through a lot of thick heavy brush like sage or tumble weeds a lot then they might pull a line free. But for normal trail use the lines never snag anything.
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.005s) Memory: 0.5947 MB (Peak: 0.6491 MB) Data Comp: Off Server Time: 2026-06-17 01:37:45 UTC
